Mugabetown - Whoretownin' At It's Worst.
Yes, I would like to take this opportunity to thank Pete for coming over to help me with a massive dump, couldn't have done it without you... :P
Here are some photos, (suppose its about time I make a build thread though lol)
Here is all the shininess in its final location:
68f763ea-4390-4c34-aea4-cb26c629b682_zps
Old vs new: 691a06ef-7622-4146-8d36-ac6db647780e_zps
This will probably cause the best improvement, the old throat was LITERALLY a 1" square passage! (Fck you Mitsubishi):
c555186a-d5a9-40d0-ae6e-6de41928e2a3_zps
I did the front last weekend, was considerably easier...:
e96ed7fd-39d9-42fa-9927-da5cc092a400_zps
cm'on do Magna Wagon build thread already
Jeez Pete that's going above and beyond the call of duty for friendship mate! :P
  • Like 1
A friend of mine works at the APS centre in Melbourne, posts up photos of cars he tunes. Last night he posted this...
10499601_311436359018487_698837254331416
280hp AFTER a performance tune. That's cute. Makes you wonder why you'd even bother spending that much money if you're going for performance?!
Spent bout 2 hrs in nistune today.
Swapped ecus over between pnk and silver bullet. Just to rule out the ecu as my issue. Both ecus in caras car work fine. Spent remainder of the time tinkering with mine. Think I am getting somewhere. Idle is good. Next step is mounting the wideband and going for a drive ;)
    • Speaking of diverting threads, my second ever NISMO purchase…. I think they look pretty classy and just wanted to share 😅   PS: 1st was the oil drain plug 😂
    • R12 has not been not available for....decades now. Propane is not a great replacement. (I mean, it's a great replacement, but it is a bit too flammable). R134a being the only way to go forward with an R12 system. The design pressures etc, are close enough to R12's to work. The ability to move heat around is close enough to R12's to work.
    • Out of curiosity, what's the reason for converting? I think @R3N3 might have the Frenchy's kit in the R33? I somehow think of you as the ambassador for realistic and clean street-driven setups nowadays
    • careful when running the car after a boil over. Ive heard you can lose enough coolant that it won't show the right temps because of too much air in the system (or something like that). Make sure the levels are good before trying again.  Maybe a mobile mechanic can come have a look with their scan tool ?
    • OK, just for some extra clarity - there is more than one option at Frenchy's. 1. You can buy the whole kit - with or without the actual compressor. The whole kit includes mounts, hoses, condensor, etc. That's either ~$2200 or ~$2800. No surgery required with this option. 2. You can buy just the bracket (~$600), or the bracket with the compressor (~$1200). Either of this or the above option "without the compressor" is if you already have an Echo comp or you are able to source one locally. Whatever the case, in this option, you will need surgery done on your hoses to adapt to the new compressor. When I said "the Frenchy's kit", I meant the whole kit in option 1. It is obviously somewhat more $$ than a $1500 OEM compressor. But if I had to spend $1500 on an OEM compressor, I would certainly consider spending double that to renew and significantly update everything forward of the firewall. Another option is to rebuild your original compressor. My R34 comp is currently dead and I will be most likely doing that to it if the spare one in the shed is also leaky.
