Mugabetown - Whoretownin' At It's Worst.
Yeah it was good fun, was nice to pick up a bat for the first time this year!
I picked up a bat for the first time ever a few weeks ago when we started going, that's why I am so shocking at it!
My folks want to run a car club cruise up to springbrook and wanted to know which lookouts are wheelchair accessible. So i had the arduous task of going up springbrook today. ;)
Also, the national parks people are idiots. Lookout has 2 wheelchair parks, the 500m path to the lookout is wonderful, nice asphalt surface, no steps or anything, but 2 steps onto the lookout platform. Why!?!?!?!
I mean, how hard would it be to make a frikkin ramp.
buy some cement, charge the Sneakey R with some tools,buckets and water solve the problem yourself?
Might just do that..
Here are the steps. All 500m of the path before them perfectly wheelchair/mobility scooter accessible.
Oh and a couple of photos that turned out alright. Should do a SAU cruise with a walk if enough people are interested in being out of the car for more than 10 minutes... Though being SAU i'd be guessing that that isn't going to be many.
    • Nah it factory manual not sure about ratio but it looks like there’s been some work at the rear
    • so I need a new speedo cable
    • Throwing my spoon to the soup here a bit.  When I installed a 044 back in 2012, along with the direct power mod, the car became very difficult to start. To a point I burned one starter motor as I was late for work and tried to get the thing going. With some tuning and careful use of gas pedal when cranking it became bearable. Trying to make this short as possible, but the 044 died after 2-3 years, after which I went with an AEM 320lph pump, which also died after about 4 years to my dismay. After that I went with a Nismo pump, and while trying diagnose an emissions problem, I noticed for the first time that my fuel pressure was 5bar/72psi on idle, and that removing the vacuum line did nothing. After monitoring the situation, and removing the direct power feed and going back to FPCM in attempts to remedy it, I noticed there was fuel in the pressure regulator vac line. Kept the FPCM, installed AEM external regu and the car became sooo much better in every way, including starting. And I had driven it like it was for 11 years.. Anyway, I agree these are likely two different problems, and the FP problem you just haven't noticed before. I do not know much about haltecs, but what first came to mind was the CAS, which probably is not there any more. So how is the wiring from haltec to gauge cluster? How is the battery voltage and alternator?
    • Your car was auto before? You have different diff ratio (auto vs manual i think? or n/a and turbo?)
    • +1 for getting a screen off alibaba, CarPlay/Android Auto is vastly better than whatever navigation cars had 10 years ago. I got an Android screen for my 2015 BMW, huge difference. Fully compatible with factory stuff including iDrive controls.
