Mugabetown - Whoretownin' At It's Worst.
I want led highbeams already. But they don't make any to fit r32s (yet) supposedly.
also I need to wire it up so my hid low beams stay on when high means are activated.
Led or hid? Led would be too dim
Yeah intercooler is huge. Bar has been hacked up to make it fit. Interesting on the led department ... only car I have seen to run led headlights was the holden effjay concept thing and it had a monstrous cooling system behind a 20ish watt single led
Here is another potato quality picture that shows how bright it really is, very spotlight-like beam, which combined with the HID lens lights I already have gives a very full spread. Even if I've only fitted one side so far.
Looks ok. Might have to find myself a second set of 33 headlights if they work out.
Longevity will be the deciding factor, these are cheap ones from eBay. Also, all led headlights like them use a tiny fan on the rear to cool the aluminium heat sink, I have run them for 5 mins in a go with no significant heating, but if the fan goes or lets moisture in they will probably die... Will keep you posted
    • these guys recommended to me and supplied custom 4 inch mufflers, couldn't be happier. They will spec a muffler to your preferred level of sound and know RB's well.  https://spmufflers.com.au/
    • Yeah this used to happen to me every year and a quick call would at least raise the agreed value back up / reduce the premium, but usually both.    That said for the first time on the renewal this year our agreed values went up or stayed the same over the fleet and the premium came down so that was a nice surprise.
    • I don't even go that hard core. I just say "how do you expect me to stay, when you increase my premium, and reduce the value of the car?"   Then play a game of shut the f**k up. Most of the time it's a computer that did the adjustment, and the people will happily change it around for you.
    • You just say that the premium increase seems particularly excessive (no pun intended) and that the value decrease seems unwarranted. You say that it's not 2005 any more, and that these days Skylines are generally owned and insured only by those that have demonstrated an ability to keep them in one piece across decades, and are therefore not the horrible risk that used to be assumed. etc.
    • Have a look at JS Performance Garage, just did a bit of work on a 32 GTR.
