Mugabetown - Whoretownin' At It's Worst.
Haha true could have been in Dubbo by 4am lol but I wouldn't want to take her, i've done Canberra to here twice, Canberra to Cooroy and back once and Griffith to Cooroy and back once... Boring!!!
Not ripping enough skids then.
good timing too. Can go get muddy next weekend
You know why they call it off roading......once you do it, your car is off the road (especially if you own a hilux, they love having naps on their side)
2.5 hours mo fo's!!! stupid rain.........
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
