Mugabetown - Whoretownin' At It's Worst.
in that example, sure.
when the dump pipe is fabricated get them to make a section that can unbolt so you can seal up the exhaust and have it as a screamer but also gives you the option to plumb it back with relative ease.
some people love them forever, some people like them for a bit and then just want it to shut up.
This.. My mate had this setup
Only because the abomination is a thirsty POS.
this
Mayb I plan on making it more fuel efficiant
hop to it......there is no reason the abom should use more fuel than that falcoon.
^ this. Old cars can be good if u look after them.
AU falcon is not an old car.......its newer than your GTR! by alot. still a horrible POS
Screamer pipes with big turbs and external gates give me wood... Just a warning Scott lol
V8s cracking gate = Jizz in my pants
so true, check out the McLaren P1 Jay leno garage......that engine is wastegateerific :)
this
Bodo my AU Falcon is only 5 years older than my R32. It's certainly not that new.
Haha nope, didn't u see my hectic falcoon
Indeed I did.....still wouldnt drive it by choice. but for the price...i guess you cant argue. would still go for the Hatsu or similar small FWD cheapness instead. I miss my Madaz
I just learned somthing ( and so did the irritating p plater) the mighty mazdarati is faster than mk4 golf gti....just. got to throw 3x scissors lol
i find this hard to Believe. But then P platers are pretty bad at driving :)
I assume you mean newer? to me an old car has a Carby :thumbsup:
Well gnite peps. Hope to get the Ant-Eater this week ;)
night Ants, hope to see it out and about soon.
Why? The mazda makes a few kw more and the same torque and is only a smidge heavier. It also has no lag. Which I think was the deciding factor.
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
