Mugabetown - Whoretownin' At It's Worst.
We've been over this before....
ECU isn't compatible. Plenty of servos around. Why bother.
orly?
The reason I ask is because of this
Dalby Ethanol Bio-Refinery under threat of closure. - See more at: http://www.unitedpetroleum.com.au/united/news/news-item/news/2014/02/17/dalby-ethanol-bio-refinery-under-threat-of-closure-#sthash.i1z8FdYx.dpuf
Almost didn't stay up for the race last night. Glad I did :), but boy am I going to pay for it today. Struggle street... :S
Pretty sure I will be going home this arvo to watch it online... I like 4 or the top 5 so I will like the race at least :P
Yeah. And by carrying jerry can problem solved. In fact I can fit 2 of the 20L ones in easily. It was really more of a question of do i stop at every servo along the way or do I take the Jerry can so I can stop less to save time, As I was trying to cram Leyburn and Kawana into one day. My range is limited however, yes, but honestly I don't think that i'll need to go further than a bit of planning will allow at any point in the future.
Part of it is also that i'm still trying to get a handle on the economy of the new Fuel. I was getting 17-18L/100km on the first few tanks but these were city and spirited driving, so max 400km from a tank. From T'bar>Leyburn>home>Logan servo on Saturday I averaged 14.7L/100km which is much better, almost 500km/tank range there.
Once I get the O2 sensors in hopefully it'll be even better again!
I travelled to and from bribie island though so there was some km's involved. I left my house with a full tent got to the BBQ point with half tank, threw in my 20L then drove home and once I got there I had half a tank again. A lot better than I expected really
Guess it's less painful paying $1.25 p/litre
  • Like 1
Mitsubishi ASX is a POS but fuel efficient... Just don't try to overtake, or corner at a normal speed on a slightly rough road... Needless to say it was over 10hrs in a boring car on the weekend...
What ecu are you using Pete? Nistune?
How will narrowband O2's help with e85?
Better off removing closed loop IMO and tuning for a targetted afr at cruise ;)
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
