Mugabetown - Whoretownin' At It's Worst.
FYP.
I might, but internal gate is shit for a screamer pipe.
Said eveyone who's never done one.
I built an internal screamer for my tx5 that I had an r33 turbo on it. It was all kinds of awesome. You just need to get it to seal.
Build be one, oh master of the exhaust pipe?
That's implied, yes.
I'm only being semi serious. You'd need to pay for machining, extra welding and a external Wastegate. Better to do a dived dump like scotts talkin about, for the power and boost levels you're looking at that would be adequate.
I know ;)
Would have the removable screamer pope for sprint days/drags and plumbed into the exhaust for road duties.
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
    • I don't think it's a good buy, the trend looks bad     lol.
