Mugabetown - Whoretownin' At It's Worst.
It amazes me how many catch cans are sold with no medium inside them, they are basically useless without them.
As above, put some scourer wire pads inside, not steel wool though, the wool is far too light and seems like it could blow away with a breeze.
did you add baffles and some other bits like scourer in the catch can? I find that the water condensation with minor oil vapour can still get passed back into intake :wacko:
nope. But the engine already has baffled plates on top of the camshafts - scourer in the catch can???
You need something inside the catch can to scrub the oil mist entering it so the oil remains in the catch can, otherwise it does next to nothing.
Do you have the mine's cam cover baffles?
yes, but not yet installed
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
    • I don't think it's a good buy, the trend looks bad     lol.
