Mugabetown - Whoretownin' At It's Worst.
Feel sorry indeed. Maybe they can stuff up your pay in a big way and add another digit in addition.to your normal pay
And morning all
They got it right last month, fingers crossed for this month!
Cbr500r abs
Needs more 1000 in the name.
Was reading about a bloke who makes custom 1000cc V8 bikes actually.
100K a pop....
Yayyy! Smells like vodka, italian, german, more italian and imagining the smell of F1 and then seafood... Yup, weekend plan in a nutshell...
Vodka??? how bout German beer instead?.........................wait......................seafood + vodka = imminent disaster
lol at smelling F1
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
