Mugabetown - Whoretownin' At It's Worst.
Got in my dad's Datsun to head to the airport for work today, after he reversed it out couldn't select anything apart from neutral and 5th. Dam crappy VL commodore gearbox. Woo.
3rd time its happened now. I suggested he get a new gearbox shop.
  • Like 1
Needs new gearbox.
  • Like 1
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
