Mugabetown - Whoretownin' At It's Worst.
I'm leaning towards the 33. So all I need to do now is save $20,000 and part the SS out for go fast bits money.
honestly should you do it, just fix the rust in boot of SS and get rid of it in one go.
No point having a carcass lying doing nothing
Then save and buy what you want
Plus the issue of it having no compliance or build plate and the paint being in average nick. Also I think you underestimate the extent of the rust...
Highflo, injectors pump tune etc, is what, 5K?
GTR is 20K, boost T and its making probably 30-50kw less, but has AWD, (more weight) and suspension will be stock, not adjustable. and for 20K you're not getting a pristine one unfortunately. Parts don't break any more than a GTS-t will, but when they do more money potentially, and upgrades do aswell. Twice the turbos, twice the diffs, etc.
End of the day look at how much your saving and how quickly, and if you're prepared to get a loan to get one.
Or, do HA and instrumentation courses and come work out here for pornstar money.
I know, this is why I'm not sure what I want. Would be starting from scratch again.
Yeah, dunno about the lifestyle tho :P
I was in the same dilemma, though i wasn't as far along with my old car at that stage. In the end though I figured everything i was doing I would just have to do again, so i traded up.
Buy this one? link
Buy this one? link
I know, I haven't really spent that much on mine yet.
If I had the money right now :P Perhaps I should go do $6,000 worth of courses and join you in butt f**k nowhere.
Its an interesting life for sure. Also, unfortunately, the work is starting to wrap up on this project at least, so there's no guarantee even if you do do the courses i'm afraid, pretty much every industry is like that now though.
But yeah (for the tradies), 10 hour days, work 20 days straight, travel, 6 days off, travel, work 20 days straight, repeat. Stay in camps literally in the middle of nowhere, but at least the rooms are decent, food is buffet, gym on site and the like. But yeah it gets lonely, you do get days off during the week to make up for it but most people are working on those days, which is good for going on drives or getting stuff done but not for keeping in touch with folks really. Honestly don't know how people with kids do it, but the financial rewards must be a good part of it.
all I hear is excuses :P
GTR for those who like parking them in garaghes...or rebuilding 26's
stick with the GTST for track car imo......having said that, a 33 GTR would be gorgeous. the one that Pete linked is f**king swoit
good evening all, house keys on monday!!
getting a double garage floor paint kit thingy from Bunnings straight away and painting the floor up before loading everything in :)
new house keys needs a GTR for that new garage
    • I wouldn't be concerned at all, other than to suggest having them flow tested when you receive them to confirm they are reasonably similar, and then put the highest to lowest flowing ones in cylinder 6,1,5,2,4,3
    • I’m only posting this cause I thought I had seen a bad review on these somewhere before. Any feedback? Would you guys recommend that if I do buy these I send em to RC to have em checked before installing. Or any other suggestions?   https://www.ebay.com/itm/114009965865?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=JDl-15yLQ8C&sssrc=4429486&ssuid=QTzlFXB1S-S&var=&widget_ver=artemis&media=COPY
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
