Mugabetown - Whoretownin' At It's Worst.
Eagle Rods,
ARP rod fastener kit.
ARP head & main stud kit.
Wiseco 0.20? o/size forged pistons & Molly rings.
Balanced crank Nissan bearings
Heads reconditioned O/S valves, with 3 angle valve work
JWT 500R cams, [ 2013 ]
New Hyd lifters, [2013]
New HD vtc springs [2013]
New Nissan timing belt + pullies [2013]
Turbos Garrett GT2871R.
AMS MaxFlow cast ion manifolds
New oil / water lines, hoses.
HKS blow off valves.
3? dumps & exhaust system from turbos back.
53mm Alum radiator.
1250lb clutch balanced with fly wheel. [H/D].
Under drive pulley.
Apexi AVC-R Elect boost controller.
Nistune ecu.
New coil packs & plugs.
New Injector plugs.
New 02 sensors.
Short throw manual shift. [stillen]
One piece tail shaft new unies, Tail shaft loop.
New gear box & engine mounts.
New 550hp Wilbro fuel pump, filter,
New Nissan AFM unit.
Stillen large SMI.
800CC Sard injectors + pressure reg.
New brake master cylinder.
New clutch slave cylinder & hose.
Apexi pod air filter.
HID low beam lights.
New air compressor & condenser.
Re Upholster interior and seats.
98+ spec manual gear box [ 2012 ]
Exedy 5 puck HD button clutch. [ 2012 ]
Kyb adjustable shocks front and rear with eibach springs
r34 GTT 310mm front brakes
Adjustable front camber [super-Pro]
New bearings in Alternator.
New Nissan water pump
4 Point harness drivers seat only
Aparantly made 469rwhp @ 18psi previously in WA, but I don't trust the guy who did that tune. Has gone 11.59@120. PLENTY more in it if you so desired to get those turbos into the meat of them.
Edited by MagicMikeZ32
Yep. Inside and out it is very clean. Except the wheels, I'd change them to something jap. It's got some Koya's or something on it now. 275 rubber up the back tho.
I would buy it myself if I didn't already have 2.5 in the shed, and I knew what was going to happen with my job after september...
Gday Antz! yea mate going well now working away.
Yea things kinda grinded to a halt when I got made redundant, was out of work about 12 months so car just sat collecting dust. took it out a few times but cant race it hard until I replace the PFC and fit a custom crank trigger. Else the cars going strong.
    • Yes. It's either "2 wires", or 1 wire, depending on how you look at it. It is the connection that ties the battery -ve to both the chassis and the engine. Every electron that goes in or out of the battery goes through those 2 small spots (on the inner guard and on the engine block). If those are not clean and tight, then shit starts to suffer. Yeah, but measure it again cold in the morning, after it has had hours to rest. You can't usefully test the charge state of a battery immediately after it has been running because the alternator puts a surface charge onto the plates that takes a while to soak in and balance out. It will always read higher, and potentially look properly healthy, when fresh off of charge. But hours later it can look a lot less healthy. It's also worth measuring the battery voltage while cranking, although this can be difficult with a typical DMM because the screem update rate is so slow on most of them. An analogue voltmeter is actually a better tool for that. If the voltage drops too far while cranking, it is a sign of a poor battery. Although I don't think we're necessarily looking for a weak battery here - just wanting to exclude it.
    • https://www.facebook.com/share/15ZMn5oXtc/ Updated Event (so its not private and can be shared easier)  Attempting to coordinate a big push of Stagea's to this years GTR Festival. Great event last year and hoping for the same this year.  Discounted tickets 20% off for their various tickets until the 3rd of Feb Monday. Drags, show and shine etc.  I've emailed them to ask to set a location aside for the Stageas for the show and shine - they are happy to do so if we can get them numbers, I'm happy to keep track of that. Entering as Nismo category.  I'll be road tripping up from Melbourne, would be cool to convey if people are interested, maybe there is SAU convoys from each capital? If you have ideas about that let me know.  https://gtrfestival.com.au
    • Does have series 2 airbag steering wheel and passenger side airbag also.
    • Do I have a series 2 or has someone spent money to have a series 1/1.5 look like a series 2? Everything I have read says the series 2 came out in 1996. I have a car manufactured in December 1995. The exterior, engine and interior are all series 2 other than the dash facia is series 1. Paint code is also kr4 that I believe is only available on a series 2. I have a VX Vehicle History Report and it says Grade: GTS25T TYPE M2 Manufacture date: 1995-12 Make: NISSAN Model: SKYLINE Body: E-ECR33 Grade: GTS25T TYPE M2 Engine: RB25DET Drive: 2WD Transmission: F5
    • I went to Repco to get them to test the battery using their tester (not a volt meter), alternator shows 14.3v when running, and when the car was off after the it was on full load I think it was 12.6v but the guy said it was all good. Terminals are all clean, no corrosion. Though I coulda sworn when I tightened up my alternator belt the car idles a bit higher and the steering wheel shakes a bit until it's warmed up. I wanted to confirm for the earth cable/s, are you referring to the 2 wires that are bolted onto the frame rail under the battery? I might be overthinking this a bit.
