Mugabetown - Whoretownin' At It's Worst.
I would love to see a 20 plus people run
Yeah good really busy at work we are backed up for like 2 weeks :/
I heard about the car. Really not good starting to give me the shits now. I want to see that thing on the road!
First time around those road and I think I kept up ok
Bad things happen there with large groups. In around 2004 / 2005 there was 'fight club' where lots of mountain running occurred. Things got a little crazy and the also the cops started to love it, and this was when cops were far less savage. You would be far better off keeping it to 5 or 6 select cars and having inconspicuous fun.
I would buy the dispenser but the beer choice is shite man.
Chancer is good. And they are planning to expand the range. But it's a lion Nathan product so you won't get any imported stuff.
I like it. But knowing my bad luck surrounding imports. Something would no doubt break so it would not be driveable for a very loooooooooooooooong time
Morning.
Feel like sh!t
Not enough sleep :(
Ditto this, however I have no reason for not enough sleep other than my body hates me - You are waiting for your wife to pop that would cause me not enough sleep (combined with late sleepy time)
Your luck isn't too bad. Every build goes like this! There is probably a few little gremlins left yet, but you are going well tackling them as they come along.
Knowing my luck I wouldn't have picked it up yet and already being pulled over so have no balls to drive anywhere, got RBT'd this morning on my way to work I get pulled over for RBT's often enough the officer said hello again Melissa before I got my licence out then proceeded to tell me he hasn't seen me for a whilst :unsure: Yeah because you pull me over often enough to know who I am just stop me at the mall next time and get it over with... Hopefully this isn't the start of my next RBT record, 10 times in 9 weeks so far which was earlier this year.
lo poor Mel. Looks like da local boyz in blue are attracted to ya. Next time just say to them that u have been drinking, just robbed a bank, and that this is your getaway car :P
    • I'd say the easiest way is, pick up a extended and baffled sump with fittings already welded on. Here is an example, it has 3 x -10 fittings  https://shop.maatouksracing.com.au/products/rb-extended-and-baffled-sump
    • hey OP can you remind me what the actual question was, I got sidetracked at V12. Do you have an turbo oil return leak and an unidentified coolant leak? The factory oil returns are terrible design; short, rubber and expensive to replace. They are very common to fail and a pain to replace because they are so short. Still, they are available new if you want to replace both last time I checked. For the coolant leak, any competent mechanic should be able to do a pressure test; that should show up where the leak is. It is almost certainly one of the billion 30 year old rubber lines which are now brittle as hell, you engine will be fine.
    • From the OP's description, sounds to me like the TCU is in 'limp home' mode --- that is, no actuation power to shift solenoids, and the EPC valve is shut (full line pressure). This effectively sticks the box in 3rd gear, with as much line pressure as possible, to try hold the high clutch clamped shut....and so you get woeful acceleration and don't feel any shifts (because they're not happening). If you don't have Consult or some other scanner to interrogate the TCU itself, you can test with a multimeter to see if it's in limp home mode....ie; stick it in D with engine at idle (hold vehicle with hand/foot brake), and measure the voltage at the TCU feeding shift solenoids A & B -- both should be ON (battery voltage). If they are energized at the TCU, you can unplug the harness from the TCU, and check resistance down through the wiring to the solenoids themselves -- you should see about 20ohms on each coil --- if you do, you can presume the wiring to shift solenoids is OK -- if both measure open circuit, you have to check intermediate connectors in the loom down to the gearbox (and the gearbox connector itself), and check the shift solenoid resistance at the gearbox connector itself --- if the shift solenoids test open circuit here, problem is in the box (ether the solenoids or wiring to them is bad). If you get no voltage at TCU connector for the shift solenoids (and the solenoids/wiring test OK), check powers/grounds to the TCU itself --- if they're ok, it suggests the TCU is the culprit (and you'd need to interrogate it if possible, to find out why it's behaving badly)...
    • Hey mate give Autotechnica a go, I recently got some Comfort PUs and rails from them, they're comfy and look great highly recommended! https://www.autotecnica.com.au/part-finder/nissan/skyline/r32/
    • Honestly, for a daily I would gladly rock a Camry. The more disposable the better. People drive horribly out here and road conditions are awful.
