Mugabetown - Whoretownin' At It's Worst.
Yer well I'm a pie making law breaking bakery dictating troll baiting insinuating cultivating linguistical nightmare.... But only on Wednesdays from 11 till 1 :)
Subtitle: Cunning Linguist
Well, well, well..............................guess who just called me.
AAAAAAAAAAAAAAAAAANNNNNNNNNNNNNNNNNNNNNDDDDDDDDDDDDDDDD DDDDDDDDDDDDDDDEEEEEEEEEEEEEEEENNNNNNNNNNNNNNNNNNN????????????????
Sean has been crook this week.
Only got back to work today.
Got an invoice from Hatlech which means ECU has been fixed..........................something to do with the MAP sensor which has baffled Sean cuz his issue was with the coms and had no issues with the map.........sounds like more drama is just around the corner :dry:
He told me the car is a priority since its the longest car they have there.
Next week will go back on the dyno for power run..................................................if.................. and only if.........................................................................................there are no more issue.
  • Like 1
    • Correct, I didn't put GT-R in the same category in this thread, incase I offend anyone. But @GTSBoy  knows my true thoughts on all Nissans.
    • Get more oil pressure sensors. I have 3 purely because trust no-one. It would be worth checking (if not already) if it happens on every shift. Like boring, 2-3 shifts at 60kph making 10kw with no obvious G-force on a shift with mega power. Does it still drop? Does it drop less? What if you shift at 5000rpm or what have you with no load?
    • Unless things that you want to do include reference to time. Simple Boolean logic is only good for digital inputs or analogues that have been thresholded into digitals. But unless you also have a timer function available (which would more ideally be located inside the program, rather than being forced to implement a timer outside the ECU and bring it in as a seperate digital for every time delay you want to implement), then you can't do some of the things that you might want to do. My PLC ladder logics are obviously littered with program blocks, because that's easier than building it all in ladder gates, but the most frequent of those program blocks is a simple timer, because you actually can't otherwise do that in ladder at all.
    • Log voltage. I'm suspecting the alternator. Or even maybe a bad earth somewhere. ie, seeing as it is rev dependent, I am thinking it is alternator dependent.
    • Yeah so N1 and any other larger than factory pump are pretty famous for pumping the sump dry...obviously we don't often get to spend 20 or 30 seconds at high rpm/full noise on the road so I'd still be suspicious that is what is happening here.
