Mugabetown - Whoretownin' At It's Worst.
Morning all
I imagine he starts work obscenely early tomorrow.
Bingo, up at 4:45
Engineer me thinks
Yep
bet ya he's on da big bucks. And he's smart enough to invest it rather than spend it.
I'm saving the lions share, but that's not to say i'm living like a monk either.
Investing the savings, on the other hand, needs more work
Soooo much progress for the charity cruise last night. All will be released on Wednesday. My rad hurts from progressing so far. :(
Good to hear!
Now just make sure you run it during my RnR...
I submitted QLD registration form, but haven't received a response email with pymt details.
Is this usual, or should I complete another?
Just checked google drive and your application is there. Were currently going through a change in the membership secretary role and Martin (the old guy) has been pretty flat out.
Someone will contact you shortly.
Morning all
Bingo, up at 4:45
Yep
Good to hear!
Morning Pete! 8 December for charity cruise mate. Got a pretty great route organised.
Morning all
Bingo, up at 4:45
Yep
Good to hear!
Hi Pete, what type of engineering work?
Thanks for following this up :)
    • Thanks everyone! I'll take the remote apart to clean the contacts and see how it goes.
    • Balance to the force has been restored.
    • Not sure if this helps but I had a similar issue where one of the doors wouldn't lock unless I pressed the lock key twice. Turns out the door actuators were f**ked. In the Nissan service book it says to lube it every now and again, I guess put a bit a bit of wd-40. I replaced mine and haven't had a problem since.
    • 2 things. 1. If you're going to buy a ball joint puller/pusher tool that is not advertised as being for the purpose you intend to use it for, then it is up to you to make sure, either before you buy, or after you first try (and possibly fail) that it will work for that task. 2. WTF? Putting HICAS balljoints back into a car implies retaining HICAS, which is just....dumb. HICAS can lick my left one.
    • After cleaning the contacts in the remote, if it has rubber carbon pads on the buttons, give them a little wipe with a 2B pencil to add some fresh carbon back. Just a little wipe. Not too much.
