Mugabetown - Whoretownin' At It's Worst.
  On 30/09/2013 at 12:34 AM, Bunta said:
Kids these days, cant handle thier booze! Just start earlier pass out at 9 still have 8 hours or more sleep.
I went hard from like 11-4 then slept til 6 this morning haha
  On 30/09/2013 at 1:46 AM, sneakey pete said:
So, day trading on the stock market good idea or bad?
can work nicely, the market is pretty hard to read in the last few years though
  On 30/09/2013 at 1:32 AM, t5iv said:
I was 22-24. Was heaps of fun.
I did similar 19-21 but usually I would get home have a shower and straight to work, and that was without alcohol because I was always driving just didn't sleep and lived off redbull and mars bars...
When I was 22 I would work for 7.25 hours somewhere between the hours and 6 and 6 which I chose then go and do all the things you described the working lots and the no sleep is the part that sounded pretty shit to me!
  On 29/09/2013 at 10:12 PM, Bunta said:
Engine out.
Morning! That baby better hurry up. You don't want it arriving the day you get your car back!
have been thinking that everything will come at once........................thats usually how it goes.
  On 29/09/2013 at 11:40 PM, Matty95 said:
So found out today, that seedy Sunday sesh' are not a good idea
well you get learn......................I have no doubt in my mind you will somehow learn this the hard way :P
  On 29/09/2013 at 11:04 PM, t5iv said:
Think there's something wrong with my radiator. We filled the radiator and reservoir up on Saturday, checked it Sunday arvo and the reservoir was empty. Curious..
was the engine getting hotter than usual?
  On 29/09/2013 at 11:16 PM, TREGTR said:
Could have been an air pocket
most likely this ^
  On 29/09/2013 at 10:48 PM, Captain Natro said:
Eh, temp gauge was a little high yesterday and when i pulled up I saw it was leaking. It's all good, to the falcoon
fix if fix fix it fix it fix fix fix it fix it rb it fix fix fix it fix it fix it
you know u want too :nyaanyaa:
  On 30/09/2013 at 2:29 AM, sneakey pete said:
Its hard separating the good info from the bullshit, and then figuring out how it will effect stock prices but I guess I'm a step ahead of any other industry
Day trading is pretty hard, if you were to keep shares longer its a bit easier to win but the gains are less (mostly) so you would need more capital
  On 30/09/2013 at 2:51 AM, TREGTR said:
Nah, buy in whole hog on the Skyline day/night market - guaranteed never to get all your money back... But the thrill of the buy and long term investment is worthwhile :) [disclaimer - don't take my fin advice] lol
lol @ disclaimer - so lawyer mentality
This.
    • The more I think about it, the more I should probably go with a genuine Bride seat and rail set up. But damn the $$$ for a driver and passenger seat + rails!
    • From what I understand, stock internals should hold out for a while even if you run 500 at the crank, no? Especially if you don't run a modern turbo setup that reaches power and torque much earlier than the original twins. My engine isn't unopened either, it has N1 Pumps, head oil restrictor, new crank and cams, new piston rings, ARP head studs and Cometic headgasket along with 2860-5s. Considering everything is healthy this should run fine for a while I assume. Once my engine stops leaking shit everywhere, it'll be tuned to 370 crank first anyway, because I need to legalize the turbo setup. If I end up needing a new engine because my block actually has an issue, even though GTSboy was adamant that the whole porous block story is nonsense, before putting an engine in I'm probably gonna take care of the weakspots.
    • Hah, I have no issues with what you are doing whatsoever! You clearly know what you are getting yourself into. It's just funny reading things like this. "What's that noise?" "Oh, that's normal. That's just the engine not getting any oil. Nothing to worry about. It'll go away in a moment"
    • Yeah I'm keeping an eye on it and might take it out as a once off if this doesn't fully charge. I did some research that said it's normal in equalisation charging. Voltage I thought was 20+ (faulty battery in multimeter) but now its on 15.9v, the max it should go to is 16.2v as per the manual. I'll provide an update once hopefully it's actually fully charged and in float mode. Waiting for it to go to 16.2v and not higher and see what happens. What I suspect has happened is that even though it's not an old battery, I did leave the car turned off for almost 4 weeks at one point then left it off for another 2 weeks which might have erroded the battery and is taking a long time to do this equlisation charge.
