Mugabetown - Whoretownin' At It's Worst.
Morning all
Tony He was talking about the box hahah
Same box, different electrics though.
Is it fixed yet?
put phone on floor
stamp on it till screen goes dark
check if turns on
- repeat if still turning on
if not predictive text is off
This guy, he knows.
not good Chris......if u don't make it I got dibs on Chrispec :P
Only if you promise to look after it and treat her as good/ if not better then I treat her and never sell her to someone who won't look after her
Well laa dee darr
^ this
I can count to twenty and don't even have to take my shoes off most of the time aslong as someone is willing to help me.... You don't see me gloating
^ this
Holy jeebus this made me laugh a little bit too hard haha
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
