Mugabetown - Whoretownin' At It's Worst.
Gooood morning folks. you know what day it is today? Home day!
V35's don't have a rear wiper. Cause inferior model of skylines etc. :rolleyes:
Does your work have any policies regarding Fatigue etc, particularly with driving?
Not familiar with V35s, that would explain it.
WHS Policy would be a great example :)
Have you seen my brakes? :P
One thing that I don't understand is, you've done so much to yours and it's pulling 285rwkw. Why are the z32 guys then saying that it's easy to pull 300 rwkw from a VG30?
I refer to this: http://www.skylinesaustralia.com/forums/topic/432767-300zx-tt-potential/
It can be done easy enough. I have a stock 24year old bottom end so I am only running 17psi. Turbos are good for another 4/5 psi. And they are just the little 2560's ;)
Edited by MagicMikeZ32
Morning Ants. How goes the new additions? Both car and kid?
its good mate. So pleased to have them all at home.
Back at work today, so can't play much with GTR nor spend time with my little one :(
But need money and so does my boss which is totally understandable.
    • The only high-power RB I've personally seen go pop after running for all of an hour on a dyno was built by B2R, while being remotely tuned by B2R. The only wastegates I've ever had leak like a sieve, return, still leak, return and get shipped back the wrong ones were from Turbosmart. The only final drive that I've ever purchased that were unusable, twice... were from Speedtek. The only seat mounts that I've ever purchased that placed the seats in the door frame were from Crank Motorsport. The only poorly designed parts that I had the manufacturer confirm should have been designed as per what I mentioned were from GKTech. The only ECU I've had firmware updates consistently break things are Haltech. The only catch can I've purchased that didn't fit in its advertised spot was from ATP. So forth and so on... Moral of the story, doesn't matter where it's from. Do your research beforehand and stick with products and companies you've trusted in the past.    @joshuaho96 If you want it done right, do it yourself.
    • Something coarse-ish. 180 is good.
    • I was surprised to see all the quick Jack models at the same prices on there. But yeah, grabbing one at 20% off would be great.
    • I wonder if these would be discounted when they have their big sales? because if so would be a great time to actually buy them could even end up cheaper than buying from quickjack in the end.
    • Which grit sand paper did you use on the pulley btw? Thought I'd ask so I don't scratch it up too much
