Mugabetown - Whoretownin' At It's Worst.
Ok I'm back I missed her :(
How could you miss her? You never met her! Are you like one of those teenage kids who goes on two dates and beleives that the girl is the love of his life? Seriously dude! Man up! You're making us look bad!
Wow, I am really being an asshole today. :/
ok northsiders. WTF is the appeal with the northside. everyone is old and quiet and at paddington, rich and boring. i cannot see anything interesting in the local shops and the northside shopping centres are holes full of bogans (Germside Shopping Centre).
when the lease is up i think i am moving to northern NSW to party like it is 1999 for eternity. or at least until i have a stroke or heart attack.
"Likes This"
Whoops wrong site
What I meant, professor smart ass, is that I went to the whore town and she wasn't there ie I missed her not I miss her...
ask Clint. The man knows
Great for rim's. Unless it is a pro job it looks like total Ass on avehicle. What application are you looking to use it for?
x2
Bad job was bad
Over rated shit that looks cheap and nasty, saw a soarer done in it.... Looked bad and he should feel bas
Non pro job was non pro.
Bottom line is after much research it is not worth the effort, Go See Rush he does the hell mad wrapping.
Don't do it is the simple answer, if this advice is ignored please let us know when it is done so we can point and laugh as unless they are an exp spray painter it is going to look incredibad.
What are your plans for tonight?
    • Yeah, you want the IACV to be running at around 30 "units", variously called "steps" or "duty cycle" depending on the person. That gives it room to go lower if need be and higher ditto.
    • Ah right that makes sense.
    • The RPM is just a target, the ECU will adjust things to try and hit that target but it's by no means guaranteed. If the IACV duty cycle is 0 or something like that and it's actually closing up fully then the idle is as low as it can physically go without reducing ignition timing. The problem can be something like the cold start valve in the IACV not closing fully, worn throttle shaft seals, torn rubber diaphragm in the brake booster allowing unmetered air, etc.
    • Apexi, though I'm not comfortable with setting the idle, knowing me I'll f**k it up lol.
    • What ECU is on your car @silviaz? You can just change the idle target table yourself and the IACV duty cycle. Noting that if you play around with the screw you'll also need to revisit the idle base duty table as you will end up offsetting the lot. Another reason why DBW is superior, there's less mucking about.
