Mugabetown - Whoretownin' At It's Worst.
One way so solve a lot of thoes, 26 head ;)
There is threads and PDFs and a mountain load of info on them I think I should be pretty right to tackle it. No doubt I will encounter issues but this is a learning experiance and training for me, and not sure on if it will be going in mine or getting sold, ATM if I sell it Kathryn's had already chosen what the money from it is going towards
Biggest tip - buy a Dremel tool with metal cut blades. The timing gear is a real c-bomb to get off - cut through the key way first and opposite side second and when almost there crack the final bit by prying apart. That way you won't nick the crank. I know someone wrote about this on SAU, but what they wrote doesn't go far enough.
Can you post up a link please :)
hi guys i have other things i want to get done soon so im looking to sell my car as many of you that have followed the build know there havent been any corners cut here its all the best parts and car is set up ready to go.
have hardley driven it to be honest and its part of the reason im looking to off load it, its doing nothing sitting in my garage week after week and i want to travel next year.
feel free to ask any questions via PM on here, or email me on info[@]isurrounds.com.au
looking for $ 30,000 firm
details :
Engine:
2.3lt stroker motor
Manley knife edge billet 100mm balanced crank.
Wiesco hd1400 pistons 9.0cr
Howard's ultimate duty billet I beam rods upgraded arp bolts.
Acid dipped block honed and decked
New Walsh plugs.
AMs balance shaft delete.
Ported valve thoats
1mm oversize super tech valves
1mm oversize super tech black exhaust valves.
Super tech double valve springs.
Super tech titanium retainers.
Super tech stem seals.
Greedy adjustable cam gears.
Kelford 280 cam shafts.
Custom air box
Custom 4 inch intake
Custom oil breather catch can with speed flow fittings and Teflon lines.
Kiggly Hla oil pressure reg
New water pump
New oil pump
New gaskets
Acl race bearings
Map h11 head studs
Oem head gasket
Pwr alloy radiator
Custom inter cooler piping
Hdi hybrid inter cooler
Precision 6466 bb turbo
Jmf tubular steam pipe manifold heat coated
Turbo smart 45 mm hypergate
Custom screamer pipe
Turbo smart race port bov
AMs rocker cover plate
Custom sprayd rocker covering
Upgraded thermo fan
Clear timing cover
Gates racing belts
I'd 2000 injectors
Ams billet fuel rail
Turbo smart fpr 800 regulator
Mitsubishi fitting kit
2x intank wahlbros
Upgraded braided Teflon fuel lines to rail
Speed flow fittings
Upgraded fuel filter
Braided lines to reg and flex sensor
3 inch custom v band dump pipe heat wrapped
3 inch full straight through exhaust
De cat
3 inch muffler
Lightened flywheel
Quarter master 8 leg twin plate clutch with hydraulic release bearing and STM clutch cable
Standard gear box
Standard Diffs and transfer
Ohlins DFV adjustable coil overs
White line adjustable front sway bar
WhIte line adjustable rear sway bar
White line bump steer correction kit
Standard strut brace
Haltech ps1000 ecu
Haltech air temp sensor
Haltech oil press sensor
Haltech fuel pressure sensor
Haltech wide band afr sensor
Haltech boost solenoid
Haltech flex sensor
Haltech 4 bar map sensor
Haltech race paq dash display
Upgraded dba 4000 slotted brake rotors front with project mu pads
Upgraded dba 4000 slotted brake rotors rear with project mu pads
Enkei rfp1 black wheels 17x8.5. X +22
Federal rsr tyres
Carbon fibre boot lid
Standard boot lid
Recently fully serviced with all Diffs oil changed , gearbox and motor done
Motor has done 2,500 Kay's since build
Car was tuned by Powertune
501.4 kw @ 42psi
link to sale thread on Evo Oz http://www.evolutionoz.net/forums/index.php?showtopic=87686
Biggest tip - by a Dremel tool with metal cut blades. The timing gear is a real c-bomb to get off - cut through the key way first and opposite side second and when almost there crack the final bit by prying apart. That way you won't nick the crank. I know someone wrote about this on SAU, but what they wrote doesn't go far enough.
Yeah had to deal with this on a rb20 at the workshop
We cut and cold chiseled till it split
But this one has a bit of oil around if so I recon it will come off pretty easy
Also sprayed it with inox and will let is soak over night
RB30 are an absolute pain in the a - I inoxed and wd40d the hell out of the last three and still had to cut gears, even top line pullers wouldn't sit behind gear. I can't understand how they rust on the inside of a press fit machined surface??
That list of mods was like a tick the box exercise compared to my E3 - with exception of I have a better cooler, I also have block o'ringed and head receiver grooved and 290 by 11.5 cams.
you have too many crazy cars :P
I know, I know. I am seriously wondering whether OCD can manifest in car collecting :)
Thanks for your help on Sat :) I am looking into getting Hardrace components for the top camber arms. AND the Craziest has now begun :)
It's not press for they slide on and off pretty sure they might be a tight fit but I don't rember them being press
But if they are you learn new things everyday
It's a very tight fit - does have a keyway lock. Cannot understand how they rust there??
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
    • Hmmm interesting. Mine is the exact same and clearly the right one.  The mystery of the engine oil being full after 3.5-4L continues
    • Yes I as well would like to find out where I could get some of the seat material with the red or blue small squares in it
