Mugabetown - Whoretownin' At It's Worst.
i was thinking it was a next mod for the 33, so his fantastic idea is to replace the waterpump? :unsure:
Nickies water pump on the falcon is fubared tits!
Im sure that his next mod for the a-bomb would be more exciting than said water-pump mate
that evo i posted the graph and such for, same turbo as you.
Mine is a T66 ceramic roller bearing Turbonetics it's a Q trim F1 wheel which is the biggest they fit for T66. I have kept exhaust housing small for spool up. It has a dual fuel system too - three rocket switch panel hidden inside centre console. Meth tank and twin 044 plus surge in boot and a seperate Walbro in regular tank for 98 fuel. A lot of the details are hidden.
I am off my ps, how do you think I have a v8?
The no fi is due to weight/capacity laws not age, plus I don't wan a glorified pump stuck off my motor, real engines dont need that shit to be quick
Not what a Top Fuel driver would say! lol
Mine is a T66 ceramic roller bearing Turbonetics it's a Q trim F1 wheel which is the biggest they fit for T66. I have kept exhaust housing small for spool up. It has a dual fuel system too - three rocket switch panel hidden inside centre console. Meth tank and twin 044 in boot and a spate Walbro in tank for regular fuel. A lot of the details are hidden.
i meant scotts car, the one pictured above.
    • So you’re saying pretty safe to put back on the high flow. I guess I will lose alittle horse power which is fine. Never heard of timing scatter? My idle has been an issue running rich since I put on a custom intake with smaller pipings so not sure how it will react to the high flow cat also - would add some more back pressure to the system no?    Thanks
    • I'm pretty sure that HK would only have the same blend all year 'round, but whatever.
    • Just put a Haltech in it. Be aware that there is little extra speed available, so almost any money spent on NA "tuning" is wasted. Far better to spend on brakes, suspension, etc. Be also aware that the auto will die behind a turbo, so a manual swap is not a bad idea. Be aware that parts for these tasks are becoming very difficult to find.
    • Another thing I would do if I was studying mechanical engineering   Eh if I won the lotto I’d do it. Otherwise yeah just a day dream.
    • My son has an R34 gt auto. I'm looking at methods on how to tune it with the view to be able to further tune it down the track when he is off his P,a and can go turbo. The issue is the 98 gt auto has a seperate TCM and is not compatible with swapping out a gtt auto nistuned pcm ( from what I have read so far ) Please if anyone has info on what to do here I would much appreciate. Realise that some options include manual swap, manualised valve body. Just hoping there is a more direct running option I haven't been able to find. Thanks in advance.
