Mugabetown - Whoretownin' At It's Worst.
I'm alright man, just crawling around under a bench looking for a pot I can't find lol.
Also discovered if you drop a raw egg into protien powder and water and whip it it makes it thick and bubbly and awesome...
Mangs exciting times ahead. Put an offer in for a house this morning. Let the games begin. Agent is a massive douche so having fun lowballing him like a mofo lol
so, the angel won out with the house vs car decision
excellent news!! hope that it goes well
good times indeed. Hope it goes in your favour including the right price.
anyone know a good smash repairer?
An Armaguard truck decided to use my 7 series as a bump stop yesterday and i needs to get it going again.
you really dont have much luck of late Benno?
not sure on any good smash repair guys around you mate.
Hopefully some other guys can point you into a good direction
We've got about 900k over the 2 houses :(
im not even gonna go there Mike.........its all too depressing to think of FTM (we went and purchased our house at the wrong time and are paying a stupid amount for it when I know all too well its not even worth that much).
was kinda pushed into it though........but hopefully in time it will be all worth it.
you are the second person to say that to me now. I am feeling lucky though. i have some health and manage to still have some fun so i consider myself quite lucky. so many have it worse.
    • The more I think about it, the more I should probably go with a genuine Bride seat and rail set up. But damn the $$$ for a driver and passenger seat + rails!
    • From what I understand, stock internals should hold out for a while even if you run 500 at the crank, no? Especially if you don't run a modern turbo setup that reaches power and torque much earlier than the original twins. My engine isn't unopened either, it has N1 Pumps, head oil restrictor, new crank and cams, new piston rings, ARP head studs and Cometic headgasket along with 2860-5s. Considering everything is healthy this should run fine for a while I assume. Once my engine stops leaking shit everywhere, it'll be tuned to 370 crank first anyway, because I need to legalize the turbo setup. If I end up needing a new engine because my block actually has an issue, even though GTSboy was adamant that the whole porous block story is nonsense, before putting an engine in I'm probably gonna take care of the weakspots.
    • Hah, I have no issues with what you are doing whatsoever! You clearly know what you are getting yourself into. It's just funny reading things like this. "What's that noise?" "Oh, that's normal. That's just the engine not getting any oil. Nothing to worry about. It'll go away in a moment"
    • Yeah I'm keeping an eye on it and might take it out as a once off if this doesn't fully charge. I did some research that said it's normal in equalisation charging. Voltage I thought was 20+ (faulty battery in multimeter) but now its on 15.9v, the max it should go to is 16.2v as per the manual. I'll provide an update once hopefully it's actually fully charged and in float mode. Waiting for it to go to 16.2v and not higher and see what happens. What I suspect has happened is that even though it's not an old battery, I did leave the car turned off for almost 4 weeks at one point then left it off for another 2 weeks which might have erroded the battery and is taking a long time to do this equlisation charge.
