Mugabetown - Whoretownin' At It's Worst.
My parents want me to buy a Mazda and I'm like hmm no. They're like $25000 and they won't let me move out either. I think I need to finally act like a real 18 year old. Starting with friday, getting another piercing, yet another thing they said no too.
NOOOOooooooooooooooooo!!!
second this motion!
Also I was 19 when I got my R33. Dad has always hated it... How unimpressed he was when I bought home the supra a year later and had two "hi-po" cars. Lol
He still hates my R33 and I haven't driven it in 4 years!!!
I don't like manual skylines. I don't wanna brake them
R33 gearbox will take what ever you throw at it if you are making less then 250rwkw...
Mine was making 360rwkw and took flat shifts, clutch kicks and track days. Magnetic sump plug had barely anything on it after 15,000km of abuse like this. It doesn't crunch, doesn't grind, only thing it's shit at is shifting into 5th quickly at high speed (going from 4th to 5th at 6500rpm).
Let it have a slightly slower shift and is happy as!
LOL!!! I got my nose pierced when I was 16 and on holiday with a friend and her mum, I rang them and the response was "your body do what you want" that was actually a sarcastic response, I got it done THEN found out it was a sarcastic response, ahh well... If you are over 18 they can't make you, and if you buy it then the worst they will do it tell you to move out and well since they won't let you know it fixes two problems :)
And I am Melly and I support Ants in supporting said statement...
*high 5*
motion passed.
lol......think we just became more efficient and effective than majority of those pollies in parliament :D
    • If the RB29 box in the car is a push clutch, then yes, you will need to deal with the pull clutch on the turbo box. You either buy a pull clutch and don't use the old one, or you do the things needed to convert the turbo box's clutch arrangement over to push. Which is a bit of a f**karound. "Making" a custom tailshaft is the easy part. But you will need to source the front clip yoke - the bit that goes into the output of the gearbox. These are not as easy to find. They are out there, but they don't grow on trees the way that they used to.
    • Indicator bulbs are way too bright to use as a "corner marker" (we call them parking lights too). Sure. Go ahead and do it. But realise that you wil need to come up with all your own wiring to do it, as no-one will have a standard howto worked out for Skylines. It's just a matter of abandoning everything that Nissan have done and starting from scratch. You'd probably be better off retrofitting tailght/brakelight globe bases into the front indicator housings and using the taillight circuit for your corner marker and the brake light as the indicator. You'd need to work out how to kill the marker circuit while the indicator is flashing, otherwise it won't flash on-off, just bright-less bright.
    • Hi. A little bit of an update. It maybe(hope not) looks like i would need a new tranny(it would be "maybe" a cheaper or better option anyway) So i need some info. I know i need a different propshaft(i can make custom one) LSD is not a problem cuz the engine will be still(for now) N/A RB20. So if i buy RB25DET NEO tranny...is there something else i need? I read something about push/pull type but i do not know if i need to "change" something or i can just plug n play onto my engine a go? Thanks for the advice
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
