Mugabetown - Whoretownin' At It's Worst.
Mmmm Nitto gear, that's some sweet stuff!
Someone has too much money (Compared to me) :P
Easy come, easy go. Spend it all on silly stuff like cars. seriously, world's worst person to copy financially. Plus, ultimately can only ever drive one at a time. I should have become a liquidator to highlight my talent... sell stuff for 5 cents in the dollar lol
I have followed the Nitto R&D their crankshafts and I-beam rods are unbelievably strong. Good thing about Andrew is that he'll let you buy the bits and pieces component by component and gives you all the clearances and tolerances to set it all up. Buy rods for 3.2 stroker first and then you're committed to the rest :)
Hmm replacing a heater core on a r33... Doesn't sound fun
2 ways to swap it, one involves disconnecting the A/C lines requiring a regass and the other is pulling the whole dash out... I bought a brand new core from the UK 6 months ago.. that's as far as I have got
The other involves yelling "FUGGIT" and just linking the heater hoses in the engine bay... LOL
Here's the secret to a cheap heater core install - find a wrecker that wrecks Skylines only. Ask wrecker to do a cashishy :ph34r: job to install new heater core. They take them out so often that they can do it in no time at all without damage and remembering where everything goes :)
you used bing...that's a paddlin
aspirations and goals are a good thing mate!
Dream are unfortunately still free.
    • Don't do it if your gearbox box has already having syncro issues. The short hifter will put a greater load on them. If you must I remember Nismo did a shorter shifter, with the top part being physically shorter and the part that went into the gearbox was the same as stock. In saying that I've had a C's short shifter (I think) in mine for many years, which was given to me as the previous owner was not sympathetic to the gearbox. Thus forwarned I was careful and had to modify my normal changing style. You have to be super accurate with your clutch and shifts
    • Well, after a week of daily driving and having to crawl out between the wheel and the side intrusion bars. I got myself a quick release setup. I went with an NRG short hub and Quick Release with some cute heart cutouts on the pull tabs. Nice and matchy matchy with the rest of the interior accents I have going on.  The only downside is the total stack height even with the short adapter is longer than the old HKB boss kit. Luckily I had some adjustment left on the column so move the wheel away.
    • stock shifter with new bushes, springs and cup will improve it. Gktech do all the bits. The opinion as the years have gone on is the redline is not great in old gearboxes.
    • Hi all   what short shifter do you use on your skykine r34?   my synchronous does have a problem and i was getting huge delay and grinding sound between 2nd and 3rd, did put shockproof red heavy stuff and it is great now/ no issues   would in your view short shifter screw this up?   people seems to suggest/ use cube short shifter and there is standard and premium. Seen review of premium as much better and less play. Thoughts?
    • Yeah, there's a bit of a density and friability difference between pebbles and any of those other things. Silicone will definitely float in oil and so will be mobile enough to move around. Although, again, if it is upstream of the filter it really shouldn't go any further. I would only ever worry about silicone when it is in places downstream of the filter. Upstream of the pickup is a whole 'nother matter. We've all seen what that does. I have seen the most abominable crap settled out in industrial gearboxes, trunnion lube systems and the like, without any sign that any of it has touched anything in the machine. Just chilling in the bottom, waiting for the inevitable operator error that causes the whole machine to need to be dismantled for repairs.
