Mugabetown - Whoretownin' At It's Worst.
I already have an exemption... For a turbo.
And hopefully I'll be buying the NA Saturday. If not turbo it is.
I rather get an NA now cos then if the cars in good nic keep it till I can swap the engine and it'll be sweet
If that's the case, then why not get an R32 and upgrade to a RB25 when you're ready? Lighter, prettier (in my opinion) and a 2L NA won't chew through fuel like a 2.5L NA would.
If you are set on getting a R33 NA, then make sure that it is 100% straight and manual. That way, you can flog the box (lol!) and it will take a beating. Will also teach you how the car moves and then you can put the head on a 30 and boost it - which is not as easy as it sounds but anyway.
It's auto, been re painted. Engine looks in good nic, r32s look weird to me. I can't drive manual skylines. I can't change gears properly and I don't want to learn.
thats not the attitude to have. I will teach u Kath in da GTR!
I can drive manual. It's just that from first to second sucks. Plus city driving is much better in an auto
This is true but you get used to it. If it's a factory or forgiving clutch, then you'll be right. No fun to be had in autos really.
Autos are designed to be more efficient and economical. I know that in mine, if I'm in D, the car isn't willing to stay about 2.5k rpm even when I'm hammering it. Eg: going around a corner pretty hard, you lift and the revs drop right down as it will automatically select the most economical gear. Whereas in tip, the TCU switches to sports mode and allows a lot more free revving. Don't know if the older manuals had this option. Also, if it isn't tip, how are you going to chose the right gear? If you're in traffic and want to give it a bootful around someone at 60kmph, the box will have you in 4th and you won't have the torque there. Just saying, that if you plan on building the car in the future, get as many things right now as possible as parts cost cash. You could be paying up to $1k for a decent RB25 manual box whereas buying a manual now may only cost an additional $300-$500. f**k with it, learn to drive it, destroy the clutch and replace it. You'll still be better off financially.
Don't get me wrong. Autos are great but if you want performance, it should be a manual or a very smart auto box.
  • Like 1
Just to ensure that there is absolutely no sex discrimination at play here... I just discovered that I cannot drive manual either can you allow me to test pilot teach me too lol
just discovered eh? what did you do?.........................have a sudden case of amnesia?
I just wanted to get closer to Kath thats all :nyaanyaa:
    • Speaking of diverting threads, my second ever NISMO purchase…. I think they look pretty classy and just wanted to share 😅   PS: 1st was the oil drain plug 😂
    • R12 has not been not available for....decades now. Propane is not a great replacement. (I mean, it's a great replacement, but it is a bit too flammable). R134a being the only way to go forward with an R12 system. The design pressures etc, are close enough to R12's to work. The ability to move heat around is close enough to R12's to work.
    • Out of curiosity, what's the reason for converting? I think @R3N3 might have the Frenchy's kit in the R33? I somehow think of you as the ambassador for realistic and clean street-driven setups nowadays
    • careful when running the car after a boil over. Ive heard you can lose enough coolant that it won't show the right temps because of too much air in the system (or something like that). Make sure the levels are good before trying again.  Maybe a mobile mechanic can come have a look with their scan tool ?
    • OK, just for some extra clarity - there is more than one option at Frenchy's. 1. You can buy the whole kit - with or without the actual compressor. The whole kit includes mounts, hoses, condensor, etc. That's either ~$2200 or ~$2800. No surgery required with this option. 2. You can buy just the bracket (~$600), or the bracket with the compressor (~$1200). Either of this or the above option "without the compressor" is if you already have an Echo comp or you are able to source one locally. Whatever the case, in this option, you will need surgery done on your hoses to adapt to the new compressor. When I said "the Frenchy's kit", I meant the whole kit in option 1. It is obviously somewhat more $$ than a $1500 OEM compressor. But if I had to spend $1500 on an OEM compressor, I would certainly consider spending double that to renew and significantly update everything forward of the firewall. Another option is to rebuild your original compressor. My R34 comp is currently dead and I will be most likely doing that to it if the spare one in the shed is also leaky.
