Mugabetown - Whoretownin' At It's Worst.
Manuals are evil
No
Gladly, yours would no doubt pay a fair bit better than mine
Yes but it can be a shitty job
And slow ;)
No
well see about that uncle Natro
This
Only time an auto should be in a jap car is if its a 2 or 3 speed and used for racing.....
And this
Trannys are good - I love me some Trannys
FYP
Going to be keeping all the associated turbo parts off the 25 skyine incase s*it breaks
Suggestions a for turbos for the dirty? Don't know whether twin or single
Something that's 300 to 350kw max, more than that is fairly unusable without big $$$ tires and borderline too laggy for daily use.
A gt30 with a .82 rear will drive almost as nice as a stock turbo 25, just that it has 300kw instead.
I reckon if you go to the trouble of building a 30/25 then you should choke it up with a small turbo like a GT30.
To get the true benefit of the change I reckon a GT35 or larger is a must.
In saying that Ive never been in a 30/35 running a GT30 variant so not sure how it would drive
Inestment home or residence colin?
Still undecided yet. Its nearly 1k a week rental at the moment so it will be tough to let that go lol. Would still get decent rent if we lived there and rented a few rooms but we dont know yet.
Yeah Ants capt barrel roll is me so wanna get into another one
i had a 35 on mine, too much power for daily duties and enough power to make it about as reliable as a rotary. power came on hard at 3500-4000 and insta wheel spin on anything short of near new 255 semi slicks.
a GT30 with 0.82 would give near on stock turbo spool, but an extra 100kw, a 1.06 rear would tame it down from being so agressive onto boost, but obviously that comes with more lag.
GT30 size turbo is the SMALLEST you can go on the 3L without choking it.
check out the results AL from victoria got with his 3L with GT30, decent power/torque everywhere and the benefit of being able to keep it looking mostly stock if you wanted to, if i was to do my car again. thats the combo i would go for.
Guess mine will be interesting to steer then lol.
I'll have a look for those results. can never look at too many :-)
Congrats Col, I looked up 5 bed townhouses, I think I found the ad. Looks nice! If you are getting the stamp duty concession you need to live in it for 1 year with occupancy starting within one year, and renting out rooms counts as you not occupying it. Something to keep in mind!
eggszachary
these results. i believe the full specs were somewhere in a mountain long thread. but it was from memory it was running a 9:1 comp ratio with some minor head work.
Just realised that i haven't updated my results.
Officially the engine is now out flowing the turbo, but i will not change the combo for anything.
Below is my full tune as it stands now.
The car has been booked in for next week to get the following done:
- Change exhaust and see if any gains are made. Currently i have the more quiet exhaust fitted and would like to compare this result with the Apexi cannon exhaust system i have laying around.
- Play with my cam gears. I still have VVT active, but have modified the std gear to also be adjustable.
- Clean up the afr. Dips too low up in the higher rev range.
- Play with the boost settings, to come on harder on high boost.
- Most important: Find a pair of tyres that will hold traction on the dyno. So far i have tried 4 different pairs of tyres and all have lost traction on full boost at high rpm. I have tried: Hankook K104's, Bridgestone RE55s, Toyo T1R's and another pair of cheap ass tyres from another 33. Anyone know of a good pair of dyno tyres????
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
