Mugabetown - Whoretownin' At It's Worst.
Colin... how big is the garage for later storage? :)
^This is important... lol
My requirement was double garage attached to house plus room for at least another double garage in the yard... Until we upgrade in which case it will be even bigger :)
not entirely accurate. Should u purchase a primary place of residence and rent it out you will not be subject to any CGT should you elect that property to be your main residence.
Ah, so if you Buy a house and rent it out, yet still live in rental yourself, you can count your rental as your primary place of residence? Would this not cause... certain issues, if the tax department ever decides to check up on it?
that is accurate. No CGT on main residence.
How can you pay CGT on an asset you do not own?
Excellent priorities - planning for future car family expansion lol
FYP
Nice yes this.
Only downside to the place. Single lock up and 1 car space in the complex. Confirming at the moment whether the car space is on the title. It comes up on the RP Date report but unsure if it's on the title.
i wished my garage waz huge with hoists and awesome tools
This is the plan. I really want to design & build my dream house so this is definitely on the cards. Sheds etc depend on where said dream house ends up. I'd really like to do an epic basement. 3m ceilings with everything supported from the external walls. No columns!
Yeah until that time I have mum n dads place which is full of my cars and shit anyway.
Won't cause any issues with the tax department unless you're claiming it wrong. You can claim a portion of all the expenses associated with the house depending on how much is rented out etc. So we were going to rent out 3 bedrooms in a 5 bed house and claim around 66-75% of the costs. Now we are looking at not living in it at all lol and just renting the entire thing, f**k it.
Nice yes this.
pls be very careful with what you are claiming as a deduction. Plus there are tax rulings in place for situations like yours that can have major adverse tax effects ie cause the MRE to not apply
Nice yes this.
Can hook you up with good accountants if required.
Would be a big value add for extra car space :)
    • It was roughly 3.5 hours.    car went in around 11:00 and I was done around 2:30 He did the initial runs, install the BC and then Nistune install and tune.  The best part was sitting in the lobby and hearing the skyline on full throttle at the dyno 😂😂
    • Glad it all went smooth. How long did the tuning process take?
    • Yeah that was kind of the same feedback my tuner gave me.  the boost tee is until I can sort out my plan for the electronic boost controller and what I’d get, where I’d mount the dash etc.  I’m happy with this until I can figure it out. Not a big fan of the A-pillar gauges. I’d like to get a clean install of the boost gauge - something digital like GFB.  Something like that might fit neatly where the ashtray is and look clean. I feel like replacing the OEM triple gauge is a bit extreme for a weekender like my skyline. And it’s not making crazy power to need all the additional sensors/gauges.
    • I'm about to swap my box to Tremec T56 Magnum F & initially thinking of re-using my DCS twin plate (can get it re centred for the bigger spline) but it's been called out the box will be noisy (rattle) as the clutch is unsprung.  So I'm doing as much research as possible. I'm not so worried about holding the power as I'll go the track version which on paper will hold the maybe 1000hp I make. It's the longevity I worry about. DCS told me they don't use a sprung centre as it's just something that can break. The uni clutch has a very complicated sprung centre. Any one had or heard about any issues with it failing? Thanks in advance.
    • Auto is at least 10% (from my real, actual experience with different torque converters and manual on the same setup) ~185rwkw at 11.6psi (peak!) is entirely what one would expect without a FMIC or anything else on the intake, it does bleed off towards the higher RPM so it's what, 9psi there? Note: There is nothing that can be done about this with a manual boost tee. If you want to hold it steady and gain more top end, well - You will need electronic boost control.....
