Mugabetown - Whoretownin' At It's Worst.
http://tmr.qld.gov.au/Safety/Vehicle-standards-and-modifications/Vehicle-modifications/Light-vehicle-modifications.aspx
VSB - 14
Open document and scroll down to a PDF link entitled: Section LA - Engine. This is TMR legal mandate for modifying cars/engines etc in QLD.
They also explain at the bottom why P1 and P2 are in their mind limited to non- high powered vehicles.
You've disproved your argument right there. It clearly states that if an engine that is 120% (or more) powerful than the factory fitted option, certification is required. RB25DE = 200hp RB25DET = 250hp. Clear difference that is greater than 20%.
I was actually talking about NSW. I posted above for others to view after looking into qld for you. I can read :whistling:
Dot point 2 of clause 1.1 leaves some scope for argument. I went to conference about all of this and they are seeking to nationalise. It can be done in QLD, but may require certification depending on precedent about aforementioned point.
8.1?
Who do you work for any how long have you been planning?
Brookfield Multiplex I'm a site engineer though not a planner i just do all the programming for my zones. Only use p6 for the contract stuff all my other ones are on suretrak 3. Been doing it for about 3 years.
Who do you work for?
For the record - looked up law for you after my initial posts. TMR don't make the laws, they simply interpret them and most importantly these laws are constantly changing. Law never stays still.
I never expressed an opinion on whether it could or couldn't be done. Simply posted the relevant section where all answers are found for Qld. I was trying to be helpful.
However, there is the above clause and section to seek an engineer's opinion on.
Ah I see. I've worked for Downer EDI (engineering arm) for about 8 nearly 9 years (5 as a planner), then BMA/BHP as a senior project controller, now I work for a consultant company, currently working on TMR flood portfolio
Sup All, need less sand in vagina's in here.
Can you do it...yes
can you legally do it...maybe
can you do it on the sly...yes
can you get away with it...not likely
All sorted now on to important things.
Early day, and Telstra issues resolved quick smart. Best indian call center person I've ever encountered. A little hard to understand but very helpful, and actually listened and agreed......crazy world
it is only a matter of time Bodo before call centers and the like become more effective and efficient.........and then charge just as much (if not more) than if it were performed in Australia.
will be happy days?
Just don't go shoehorning a 911 NOS fed turbo engine in there :)
or this http://www.youtube.com/watch?v=u_RCsx63UiI
I was thinking more like this
http://www.youtube.com/watch?v=sncE-uw1onE
keep it drivable :) 4play manifold ftw!
    • I thought DW was one of those things that people thought was the bomb ~10 years ago and since learnt not to use their stuff? Because it's not any better than a bunch of other options, and definitely worse than a number of other options.
    • There will be wiring, preferably crimping. The whole "skyline specific fuel pump" marketing that DW uses is a lie. It's just an ordinary fuel pump with all the ordinary bits that come with it. You still need to do all the wiring that you would have had to do otherwise if you bought something like a generic Walbro 525 pump.  Other things to consider (based on my horrible experience using DW pumps) * How is the fuel pump sock attached? On my old DW pump there was no locking mechanism, it was an interference fit and after a couple of years of driving, the sock came off. I now have a random fuel sock floating around in my tank =/ * Does the fuel pump have an internal check valve? My old DW pump didn't. Not having one is a pain. Just another thing to buy and faff about installing into your fuel line. I wish it was stated on the product box/online description 'no check valve'. The product description gave no indication if it had or didn't have one. I wouldn't have bought it had I known it didn't have an internal check valve.  * Consider the depth the factory fuel pump sock reaches in the tank. If you install the DW pump in the stock location and use the baby sized sock supplied, you will find yourself running out of fuel with like 15 litres of fuel still in the tank. + * Do you have any plans to use e85 in the future? Now is the time to install submergible e85 fuel lines in the tank.
    • I have ad blockers and automation breakers (like NoScript) installed on all my browsers on all my devices. I have a PiHole at home and use other forms of DNS blocking to prevent the advertisers, and more importantly, the trackers from google, meta and all those other kunnts from watching what I do. They learn NOTHING! Or at least, as close to nothing as I can make it. I don't care if google knows that I'm searching for things. But they can get f**ked tracking my every move. Plus, when surfing donkey porn, the automation breakers help to prevent driveby trojan installers.
    • New DW300 Fuel pump, new fuel tank lid, new plastic lock all on the way!!! I'll be on ramen noodles for a week but at least my car will have a fresh fuel pump in over 20 years! Thank you everyone for your input ❤️
    • Really? I see ads for all the JDM parts on the bottom of threads
