Mugabetown - Whoretownin' At It's Worst.
What insurance companies are best to insure skyline with?? For an under 25 year old :/
Most insurers wont touch you with a 40ft poll
NRMA will do fire\theft
Shannons & Just Car also
Allianz wont do it
This will cheer you up. AMS GTR v Lambo insane acceleration in third gear http://www.undergroundracing.com/videos.html?curVid=uCqbg8akOmA
OMG! Those gallardos ........I want one.
Just can't beat power to weight!
Does sound very good. Love the speedo blistering through the speeds......
Still can't believe the AMS GTR got chopped!
Sound in R8 V10 awesome - It's same as lambo motor but sounds insane in R8.
I know, I couldn't believe it either. This is how I came across the car.
Allianz wont do it
Nrma had a great comp and third and theft
Shannon's I yelled at and called them d!!cks
And suncorp was supportive cos the chick had a supra haha
