Mugabetown - Whoretownin' At It's Worst.
anyone know if option one is open today? tried calling a few times with alot of busy signals, and one message saying they're closed till the 3rd of January
Doubt they'd close for that long.
No idea Bodo.
Can someone do a drive by maybe?
No loud and obnoxious lol
Nick being near/ following your csr makes people think they have loose wheel nuts and a wheels about to fall off is how bad your car sounds up highways.
love those moments......then you get to have fun doing the service ;)
After the day I am having going home and servicing the car while drinking beer is going to be like a zen garden to me.
