Mugabetown - Whoretownin' At It's Worst.
You cant kill the B@man!!!!
yeah its not Scotty. The only problem is that with things like that is that you dont fully know the extent of the damage untill you look deeper.
Plus the the whole inconvenience of everything is hurtful and when it happens to your baby............well it hurts even more.
But in time, I think that the B@mobile ( :P ) will be back in action.
Thanks Boy's
So R34 got rear ended
What? how when?
What ant's said, Externally it is all cosmetic, a few cracks in the bar and the alignment of the spaces between body parts is f**ked. Beaver tail has been pushed in and the boot has been impacted into slightly. Unsure of any impact on the mechanical side of it at this point.
so many of us in the last 6 months.......f**k I hate traffic, and people...combination of both is the wurst
lol
By looks of it she got the whole B@cave
Or is it a He?? OMG the monstrosity, i just cant tell anymore.............
looks like a he and also looks like he's proud of his appearance.
Most likely dead from heart failure
Once something has gotten to that size it no longer has a gender...just a zip code.
To be honest that sounds like something that shouldve been noticed and fixed while it was in the shop.
u are probably right Zeke.
However, I really don't won't to look back at the past mate nor dwell on what should of been. Just not worth the time nor my energy.
Id rather fix it myself cause I've done it before and it will just be a case of paying for the parts and I know it will be done meticulously and correctly.
I take offence.. Im actually a 200kg man.....
My zip code is 0001
Just kidding guys, im a string bean whippit........
    • But it's much better to use a freedom unit that has four different possible meanings...
    • I would try messing with friction modifier to see if it smooths it out.  Just keep adding more until it stops chattering or grabbing quite so much. If you haven't changed the gear oil in a long time you may as well start there too in case that has anything to do with it. You might want to also verify the initial torque is set to the lowest setting too. Requires popping out one of the CV axles first but that's not too bad. Once you're sure the preload is set to the lowest you can try adding an ounce at a time of friction modifier until it feels right to you.
    • It is possibly 55 degrees for the Nismo version. I had a look through the manual and the stocker has a breakaway torque of 2.5 to 3.5kgm. Supposedly the Nismo LSD goes down to 5kgm when worn in but it is pretty grabby even with very little throttle. Worse when cold. So I guess you have three things. 1. Shims. 2 Friction plates 3. Cams Would think shims would be the easiest but Ive no clue how many tenths of a mm shim thickness change equals how many kgm torque. Also not sure if the Nismo friction plates are similar/different to stock or if they are the most of the source of the diff being angry. Think I can write off the Nismo rebuild kit for the standard diff as not being what I want.
    • Yeah, it was a bit of confusion with me, I rang and asked if they had a boot for a soft top, and then the paint shop when they rang and were asked if it had a hard top on it, which it does, just not a PRHT....LOL Meh, whilst frustrating for all concerned it isn't a war stopper and should be a thing of the past in a week or two In other N/A related news, car is booked in at the end of the month for the cams, springs, retainers, harmonic balancer and retune  I might even pull the lazy arse card and get them to do a full service on it whilst it is there
