Mugabetown - Whoretownin' At It's Worst.
Quiet day was quiet.
Drove past DOT and QPS setting up camp on the ramp to the M1 at Ormeu this morning. I casually cruised by while 6 of them all gave me the death stare.
makes you wonder how many import trophies they collected.....
Hai ants! Reply to my PM I sent you few days ago.
Or you're still too drunk to find it?
Hi Grant,
Sorry mate, I have no real excuses for not replying earlier :wacko:
PM replied now :yes:
Burnt exhaust valve, head has been sent away should be back in the coming days
should kick ass once its complete Scott.
Really need to find a nick name for your car something like the scotty-thirty :whistling:
Hey Scott, I'm building the 25 30 to lol. It's going alright, just a bit of talking and planning with dan from erd on the best way to go. Since talking my builds already doubled what I though it would. I have a fully built head with a lot of work done to it, just bought an npc twin plate clutch to handle 1000hp at the wheels. Getting under car surge tank made up in progress, working on getting harmonic balancer from Ross, but dan thinks I should look at getting the Ross trigger setup to, which is an extra $2000. So I'm not sure on that one yet, how did you go with your engine regards to timing at 4000 and 7000rpm? No jumping around or anything? And still deciding on oil pump, which will probably be a nitto pump, these are things I didn't plan on the 1st stage of the build but need all the above for balancing :(
I reckon everyone should have a crank trigger. There are cheaper ways to go though. Ask Dan about the set up in Noels car. The price ross charges is crazy.
  • Like 1
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
