Mugabetown - Whoretownin' At It's Worst.
Made some weird noise waiting at the lights like something bad broke then proceeded to drive with a horrible miss
Checked over it at the local servo couldn't find anything and car would start and run but has a bad miss.. at first thought it was the turbo shat itself out the exhaust but still makes boost...
im thinking ignition problem
But if u heard something break........that's not good.
Fouled spark plug
Check over all the connection people forget that they're all 20 years old and brittle so they easily break. Doesn't explain a Lou noise though :/
Nick has a valid point here - could also just be hose that blew off......
Yeah hopefully it's just the copper plugs I been running for far to long and not something else.
only one way to find mate - x fingers its only minor repair
Sitting idle at the lights is when it started revs where under 1000rpm
Get missfire under 3k when causing at 100km/h it seems all fine :/
When I get home I'll pull the plugs
Btw I am running splitfire coil packs only about 4 years old.
Have to get technical on this stuff.
Any description is better than a something is broken noise. Can't be that bad of a noise, otherwise (I) would not be driving anywhere after hearing it.
BTW, 3 zeds in shed. 2 engines out.
Edited by MagicMikeZ32
What kind of noise did it make? Crack, bang, mechanical metal on metal or something else? Whirr?
Bang but metal on metal noise but like a rock bouncing under the car.. first though was it's someone else's car but I did feel it in my feet..
When I took off it blew 1 puff of white smoke... not sure if it was my car or another car as it didn't do it again for the rest of the trip to work.. only thing is the big missfire
First thing I'll do is check the plugs
I pulled in to the servo up the road and checked everything I could and all looked and sounded normal... The noise before hand could be irelavant but seemed to happen at the same time it decided to run like shit
I'm inclined to think that its not irrelevant and that they are somehow associated with one another Ed.
Whenever a bang happens and then the car runs like crap - I think its rather important to find out the reasons for the cause so you can rectify it, otherwise you may think that all is well and continue driving the car until the inevitable happens.
Get to it before it gets to you.
    • yeah i agree paint match stops it from standing out so much, oh that's actually really good to know i was wondering if it would help with air flow now actually having an outlet in the bonnet. Will have to focus on ducting into and out of the radiator now to make the most of it.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
