Mugabetown - Whoretownin' At It's Worst.
Court you say.... Like a tennis court?
Baby be the class clown, I'll be the beauty queen in tears, it's a new art form showing people how little we care... Yeah
Yes, that's it I was in a tennis court - Matrix style. Literally a part of the surface :no:
Second protracted sentence I do not even understand?
TREGTR, on Today, 09:28 AM, said:
Hi All. I have been in Court on big matter, which just resolved. Back on SAU I go :action-smiley-069:
Hi Tim.
Thought as much.
Favourable outcome for your client?
im well thanks for asking.
Busy busy busy day ahead.
How are you?
I am good, busy, too busy lol but 5 weeks until I am busy away from work haha! Our house is going well we now have a roof so taht is exciting! And so far (touch wood) I am not extremely stressed out haha!
Yeah unplugged AFM then started car on stock ECU ran the same harder to start but did run
PowerFC installed to rules out ecu. Am unplugged wouldn't run. AFM installed it runs but missing..
Did the spray carbie cleaner around hoses and intake gasket.. no notable change..
Who can recommend a Mechanic Southside close to beenleigh ? If only ERD was open still.
I cant recommend you a mechanic as really I have no idea if there is even one in Southside close to Beenleigh :(
what I do recommend is that you dont drive your car to the workshop should you choose one.
have you tried chatting to Zac?
glad to hear it Mel.
Im also trying to get organised before our big trip back home to Europe this December / January so busy busy busy busy too :)
Check up on the new rules for motorcycle learners coming into play start of 2014 you might want to get your RE before they come in.
Once you find out post back here cause I have my motorcycle learners too :D
News bike L laws should only affect those getting their Ls then people who already have then shouldn't be affected. It was like the car Ls if you already had them prior to the 200hr log book thing you only had to do the 100hrs still.
Where are you building?
Also,
I think I have found out how Bunta has 4m posts lol
Thanks trying to get my post count to 10 so I can reply to PM's
You're trying to do the right thing, haven't spammed the forums to get your post count up - so there you go, bumped you to 10. Enjoy smile.gif
can you bump me to 4 million while you are at it? Just so i can be awesome you see!? tongue.gif
No, that'd be ridiculous
:ninja:
Haha, behold the awesome
this reminds me of the time squizz took joshwa's post count down intentionally just to pee him off...
now to get friendly with those moderators / admin :D
I am so jealous I want to go to Europe! How long will you be there for? I want to go and see the family in Finland and Germany but that won't be for a few years at least!
In Woodvale estate it's between Burpengary and Morayfield...
Well actually Mel, that is where we are going - Finland ;)
cuz my wife is Finish and we are going to spend Christmas with her family and also go to my brother in law's wedding there :yes:
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
