Mugabetown - Whoretownin' At It's Worst.
2 sets, no leaks etc.
1 set JIC Magic, quality jap gear. Hard rates tho, perfect for track work or mountains. Think they are 8 and 10 or 7 and 9.
1 set Tein SS, better for Brisbane shit roads.
How much are you chasing for the Teins?
Motherf**ker
My brand new second hand raw broker CAS is dead
Just swapped it back with my old one that's stuffed and is idling like normal
Fu$k
Beer time
yeh at least uve located the problem Ed.
I have a spare one here for 20?
if it works i will take it! thank you :D
really thought i would be over CAS issues since buying a refurbished CAS (all new parts inside apparently) but guess that is a risk you take :(
yeah this CAS are a pain in da ass.
And not cheap to replace if buying new.
I f**ked mine up once and was lucky to be able to source a second hand one that has not given me any issues
yet
White 1995 model v-spec
Also has
Hks oil cooler
Unfortunately, with the motor on its way out you would be looking at the same amount as the lowest trade in value, namely, around $11,800. You may be better off parting the car out, if you have the skills/time to do this yourself. http://www.redbook.com.au/cars/research/used/details/1995-nissan-skyline-bcnr33-111628?R=111628&Silo=spec&Vertical=car&Ridx=9&eapi=2 To get the thing back to where it needs to be with engine rebuild and other repairs would be around the 15k mark as a rough estimate depending on how bad it is.
Another benchmark car is a 1996 bright green skyline GTR V-Spec with all the fruit, but some interior and bits missing for $11k. It has been on the market unsold for quite a while http://www.gumtree.com.au/s-ad/mount-warren-park/cars-vans-utes/1996-r33-gtr-nissan-skyline-v-spec-repairable-write-off/1031209389
yeah already know about it
Thanx for the link.
But justifying the price for that kit is pretty hard to digest
So, this was my car on Monday....
Luckily, the hail was just sliding off the edge of this, no damage caused
It did have this cool aftereffect, i really wish my parents had used the good camera to take this one.
    • All I can say Duncan is good luck and I hope that Neil did not run any E85 in Cheryl. I have recently experienced the full spectrum of fuel tank issues in my R33's that had been caused by E85 and contaminated fuel. When you take the cover off the top of the tank and have a look inside you will get an understanding of how easy it will be. Best case situation is clean fuel with minimal contamination. My GTR was like this and it was a very simple operation to just grab the fuel pump carrier bracket and slide it up and out of the tank. My three GTS_T's had different levels of fuel contamination that was probably caused by E85 in the fuel.  In the worst case all of the metal components in the tank had rusted to the point where there were pieces of rusted metal swirling around in the tank. This required the removal of the exhaust, the tailshaft, the complete rear cradle and the fuel tank. The components in the tank were that rusted that it took days to get the fuel pump carrier and the mounting brackets out of the tank. When the tank was finally cleaned, everything inside the tank had to be replaced. With the tank all back together I could then reinstall it in the car along with everything else that had to come out. Good luck and I hope that you find a clean tank.
    • It is a two door. It is black and also still has the OEM wheels and stereo. Exact model would be KR_R32RGFEL_SS According to GTR-Registry.com is a 2 Door Coupe; RB20DE; 2WD no HICAS; MT.F5; (11L) Projector Headlamps and Fog Lights; (12_) Electronic Active Full Auto Air Con (Climate Control); (13-14SS) V Selection -- Which seems to be accurate description of my variant. Will try to upload a few pictures soon. The OEM wheels look like the below image. Image is taken from the goo-net-exchange website.
    • Time: Saturday 18th January - 9am -10:30am Where:  Cafe By Lamanna 10 English St, Essendon Fields VIC 3041  - https://g.co/kgs/mhVKvAB Registration: So we can give the cafe a heads up on rough booking numbers please rsvp below Registration Link: https://forms.gle/wPtfj9Gp8bvCiouo8
    • Welcome Gabriel. At least your car has a glorious RB and not the shitty CA18. As MBS206 mentioned all the good bits can be added later. Two doors or four?
    • And half of them have been converted to turbos.
