Mugabetown - Whoretownin' At It's Worst.
Ross can eat a dick. The price of those kits is Bullshit. I got my gear from some local guys who were able to provide the trigger, hall sensor and mounting kit for less than 400 bucks.
  • Like 3
Yes they are expensive. The principle is simple enough Motec and other companies have the sensors, it's just a p in the a to get a trigger wheel to balance and work properly.
Its pretty damn easy. Have even seen slots cut into the harmonic balancer used to trigger.
Which is why I said the principle is simple enough, but balance only needs to be out a bit for the system to stuff up the signal and cause issues. Ross did plenty of R&D to arrive at a good system, but I agree it is expensive.
Its a wheel fixed to your crank. There is literally nothing difficult about it. I am more impressed with Ross's marketing department than their engineering department on this one.
Other than an uneven cut out wheel on a 6 cylinder that are known for engine destroying harmonics.
Really? Lol. There would be hundreds of places capable of making a wheel with evenly spaced gaps in it. This is actually just getting silly now. Any way thanks for reminding me why I stopped posting here. Good night whores!
  • Like 1
I thought you stopped posting, as your keyboard was clearly bigger than everyone else's. :) Balance is critical. If it was so simple, why didn't you make one up yourself???
PS: I am actually fully trade qualified (Ask Ants) and build RB engines myself in what little spare time I have outside law. My latest build is 390AWKW SAU member's engine. Have you even touched or used the Ross trigger system, or just posting that they suck for the sole purpose of trying to contradict me? :)
Notice I put smiley faces, therefore it's a friendly post. :)
I didn't make one my self because a monkey with a cnc machine can make a prefect trigger disc in minutes. I don't give a f**k if you are qualified in every trade ever and made a 9000kw rb in your kitchen, you are wrong. There is nothing difficult about a crank trigger no matter which way you slice it, any machine shop in the country can produce the required disc. I have touched a Ross kit. Then used it to think of something else that does the same job for 1/4 of the price. At no point did I say the Ross kit is shit. It isn't, their price however is completely unjustifiable for the simplicity of the gear they supply.
I got my information on how to get the set up done simply and cheaply by a guy called Alan Heaply who also knows a thing or two about RBs. Probably even trade qualified but I would have to verify that with Ants.
if it works i will take it! thank you :D
really thought i would be over CAS issues since buying a refurbished CAS (all new parts inside apparently) but guess that is a risk you take :(
I'll see if it works this arvo and I'll let you know, shoot me a pm
    • All I can say Duncan is good luck and I hope that Neil did not run any E85 in Cheryl. I have recently experienced the full spectrum of fuel tank issues in my R33's that had been caused by E85 and contaminated fuel. When you take the cover off the top of the tank and have a look inside you will get an understanding of how easy it will be. Best case situation is clean fuel with minimal contamination. My GTR was like this and it was a very simple operation to just grab the fuel pump carrier bracket and slide it up and out of the tank. My three GTS_T's had different levels of fuel contamination that was probably caused by E85 in the fuel.  In the worst case all of the metal components in the tank had rusted to the point where there were pieces of rusted metal swirling around in the tank. This required the removal of the exhaust, the tailshaft, the complete rear cradle and the fuel tank. The components in the tank were that rusted that it took days to get the fuel pump carrier and the mounting brackets out of the tank. When the tank was finally cleaned, everything inside the tank had to be replaced. With the tank all back together I could then reinstall it in the car along with everything else that had to come out. Good luck and I hope that you find a clean tank.
    • It is a two door. It is black and also still has the OEM wheels and stereo. Exact model would be KR_R32RGFEL_SS According to GTR-Registry.com is a 2 Door Coupe; RB20DE; 2WD no HICAS; MT.F5; (11L) Projector Headlamps and Fog Lights; (12_) Electronic Active Full Auto Air Con (Climate Control); (13-14SS) V Selection -- Which seems to be accurate description of my variant. Will try to upload a few pictures soon. The OEM wheels look like the below image. Image is taken from the goo-net-exchange website.
    • Time: Saturday 18th January - 9am -10:30am Where:  Cafe By Lamanna 10 English St, Essendon Fields VIC 3041  - https://g.co/kgs/mhVKvAB Registration: So we can give the cafe a heads up on rough booking numbers please rsvp below Registration Link: https://forms.gle/wPtfj9Gp8bvCiouo8
    • Welcome Gabriel. At least your car has a glorious RB and not the shitty CA18. As MBS206 mentioned all the good bits can be added later. Two doors or four?
    • And half of them have been converted to turbos.
