Mugabetown - Whoretownin' At It's Worst.
About to service the gtr with nothi g morw than a 25 dollar socket set... desperate times ... prepare for some mcgyver like shit.. not joking I dont even have a screw driver
mate......next time come around my place and you can service GTR there
YAY Car is alive for now, drives fine on old CAS but seems a little off when boosting so will keep that to a minimum till repalcement CAS or new one. (please santa )
Plugs changed
Oil/filter changed
Fuel filter changed
multiple air leaks fixed
aac cleaned
looks like ill be attending the Charity Cruise again :D
  • Like 1
Rule 1 don't sell your tools
Rule 2 keep at least one toy ( be that motor bike/car/race car
THIS
currently thinking about selling the skyline for a Motorbike but then i'll miss you guys
Plugs changed
Oil/filter changed
Fuel filter changed
aac cleaned
Good on ya mate.
Really happy you can be driving it again without those previous issues.
Servicing done... all good I think sheared one bolt . :-/ and may have poured 200ml of oil before I realised that the sp plug wasnt in but ok really
for those that are interested
i used 1x 2nd hand socket set from cash converters $25
1x Ka bar combat knife $ had for years
2 x empty 2 lt coke bottles $0
1x 1.25 empty coke bottle cut in half $0(half for oil half for a funnel )
1x ikea flat pack allen key $0
2x XXXX gold
penrite oil $70
new filter $24
thats a gtr serviced for $120
Edited by ibrox90
  • Like 1
So anyone knoq where I can get a coil pack rail bolt from ???
are you talking about the little bolt that holds the coil back to the metal frame or the big bolts that hold the coil pack metal frame to the engine head?
I have got the coil pack bolts from supercheap before
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
