Mugabetown - Whoretownin' At It's Worst.
are you talking about the little bolt that holds the coil back to the metal frame or the big bolts that hold the coil pack metal frame to the engine head?
I have got the coil pack bolts from supercheap before
this ^ as well
every time it comes to new tyres the left rear is always much more worn particularly on the inside..
now obviously camber plays a large part in this .. but why would the left inside be so much worse.
anyone know a decent guy to do wheel alignment etc in brissy that wont ruin " mah hulla flush camba bra....uleh" ????
Too much toe or castor.
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
