Mugabetown - Whoretownin' At It's Worst.
Matty95, on Today, 07:53 PM, said:
just into hiding for a couple of days... I wasn't really in the mood to talk to anyone
well that's not very positive.
Hope h feel better now
every time it comes to new tyres the left rear is always much more worn particularly on the inside..
now obviously camber plays a large part in this .. but why would the left inside be so much worse.
anyone know a decent guy to do wheel alignment etc in brissy that wont ruin " mah hulla flush camba bra....uleh" ????
Castor as tony said plus road camber is more on the left side of the road. I have the exact same issues with my tyres.
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
