Mugabetown - Whoretownin' At It's Worst.
Who wants to sponsor me? Want to buy a brand new CAS from Nissan. Really don't want to play the guessing game with another second hand one.
Gus Oberhardt on facebook was selling one a week or so ago. Few months old, I think he said 4. Wanted 400 bucks for it. The rb26 and 25 one are the same I think?
I have another second hand CAS lined up with cowdy.
Just hate the things as it will be the 4th CAS to go onto the car and would be easier to get a brand new one but at over $600 I won't be getting one anytime soon :(
4 CAS units? I suspect something else might be at play
I have had 3..
First one on the car died
Second Hand one never worked from when I got it but as I had other issues didn't know it was stuffed
Third one that was Second Hand reconditioned capped itself....
I guess it could be something causing them to died or fail where my car runs like crap.. I am back on the second CAS where I have a miasfire under 3k which is heaps better than the reconditioned unit
positive, swapped between CAS i have and both run differently the one i went back to and currently using runs the same it did before getting a newer one..
Sure it isnt the connectors?
Thinking about buying one of these http://www.ebay.com.au/itm/CRANK-ANGLE-SENSOR-NISSAN-Skyline-94-98-R33-2-5L-6CYL-J926-CAS-ONLY-RB25DET-CAS-/131008368517?pt=AU_Car_Parts_Accessories&hash=item1e80b50f85&_uhb=1
I thought my cas had died at one point, it was a faulty wire in the loom that needed to be cut back and replaced, worked flawlessly afterwards.
If the car changes between running fine and running funny while playing around with the cable you could have the same issue.
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
    • Oh yeah, always always always turn over an engine by hand first.
    • So by that logic, an insanely expensive GTR for $200k+ is quite cheap, at 12% of Sydney's median house price compared to over 50% when a GTR was new...
    • Apologies... thought i had outlined it... Cheers for the response, I'll get a nipple sorted out for this.
    • lol thanks for the pics but some arrows might have helped for context. If you mean the bit I've badly traced in red, that is a PITA vacuum signal for the power steering pump, only R34 GTT was "lucky" enough to get it. Yes you will need a nipple of the same size somewhere in the intake between the air filter and the throttle or the power steering idle up will not work correctly
