Mugabetown - Whoretownin' At It's Worst.
Zane and I will take that as a compliment...
its how it was meant.
None of us who were at the really pointy end go and run at Texi any more. The good ol' days are gone!!!
Planning once my second r33 is done to get Sarah and i down to the motorkhanas in Canberra, we checked them out earlier and its some real competition!
Hi Mel
Hi Ants!!! :action-smiley-069:
Hi Mel! Which team would you bat for?
Queensland... I never liked living in NSW or ACT...
If you want competition go to the Sydney ones.
going to try and spray a rear bar over xmas :-/
Ants is my inspiration. whites a bit easier though.
I figure ill try whats the worst that can happen .
i f**k it..... then i rub it back and go again
  • Like 1
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
