Mugabetown - Whoretownin' At It's Worst.
Anyone have a magic wand that changes a clutch and timing belt? Not looking forward to this fix haha :P
Did come up with something very dirty to reply but decided best not too haha.
jsut a quick question on the legality of the following
flanged screamer pipe ( so has the ability not to be a screamer piper when the pipe is fitted.
carbon bonnet
carbon boot
carbon bonnet
carbon boot
#1 I presume is legal as long as the screamer isn't fitted on the street.
#2 carbon fibre panels are illegal
second one.
as im new to brissy i have no idea
anyone know of good wheel repair place in the brissy area closer to ipswich the better.
I stress good as the wheels are legit gram light's from way back
Edited by ibrox90
Morning all
Fueling issue is fixed, kinda. I'm getting about 15l/100 but with this cam that's fine :)
lol....I'd be non too impressed if my car drank that much.
My clutch too is in need of replacement, Havent tackled that yet. But the timing belt is relatively simple, as long as you have time and some mechanical knowledge......oh and patience...lots of patience. hope that helps :)
3.6 diff gears and a 2800-3000 stall = bad fuel economy :P
Because skids?
Anyone notice that jackwang in the kippa ring thread? - We are going to make these comments publicly available - It's a public forum what a f**king fool. Labeling us as hoons on our own forum when there is no evidence of such boils my blood.
    • I know right. It baffled me. There's no way when the engine is off, key is in ignition, (coils are dissconnected aswell), also my sound system was dissconnected (I don't run any audio capacitors), battery reads 12.2v and with the 10amp fuse blown I was measuring 24 to 30v. The reading would move a bit from 30v to 24v which was weird. I took a pic of the multi meter reading 🤣: (This is a brand new single channel digital oscilloscope that also has a multi meter mode).   Before when the fuse was blown, I had one lead on the 12v supply (green/white wires) of that brown relay and the other lead on the negative battery terminal. When I turned the key on ignition (engine off), it would read 30v. Then when I removed that relay from it's plug and tried putting ignition on again, it would read 12v, but I think it's because it can't turn on the ecu now that I removed it. I asked Chatgpt and this is what it had to say:   Not sure if those theories would be possible but, any auto sparkies here? welcome to confirm. 🤷‍♂️  No idea, but if it happens again, atleast I know what type of issue it is, unlike last few months where I didn't know what was causing all my issues and I was just taking stabs in the dark to figure out what type of problem it was. If it does happen again I'm going to investigate futher and trace back the source even more and inspect more circuits. I drove it to work this morning and the car drove and boosted fine. Yeah I was thinking the same, so I've imported my back up saved map (which is the map that I saved when it got done tuning) back onto my haltech with the base fuel pressure set to 43.5psi.
    • Yeh nice, if your in melbourne could you recommend any exhaust shops in the east that do a good job?
    • Sorry yes, this is what im after Also, that jpjdm site appears to be offline
    • @Duncan Random side note, did the cops give you the driver/owners details of the taxi and then did Shannons give you a refund of the excess once you supplied those details?
    • Yeah to be clear I'm not naive, I'm sure all insurance companies are a bunch of arseholes who pay people bonusses based on the value of genuine claims they avoid....I just don't want to go back to one that has personally f**ked me multiple times in the past
