Mugabetown - Whoretownin' At It's Worst.
Don't think so. Completely different auto-correct function and better feel.
That was my way of saying that it IS powered by swift key with out being a Kent about it. Lol :P
Nice looking car Pete. Details!?
1994 model, which is nice since it has the r33 engine, but the engine is stock bar Tomei M7655 turbos, full turbo back exhaust but no supporting mods eg injectors and AFM's, only making 220awkw's, that is going to change pretty soon though, no point having big turbo's and not using them. Hoping for ~320kw's once returned but will have to talk with Sean first to make a plan of attack.
New clutch in it too, very grabby, taking a bit of getting used to it.
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
