Mugabetown - Whoretownin' At It's Worst.
Latest musing on my car related shenanigans:
  • Buy consult cable, (this would work, right?)
  • install free Nistune trial software,
  • adjust injector CC and AFM to match,
  • drive car to EFI
  • Profit
Sound like a plan?
