Mugabetown - Whoretownin' At It's Worst.
t5iv
 Share
Located in Wishart Mike.
Fuel injectors haven't arrived, and i'm about to go back to site, so the 6th of march is The day that they and the AFM's are going in, I get back on the 5th and car is booked in on the 7th. Shouldn't be to hard to knock over in the day though. The software seems fine in Trial mode, it isn't cut down at all, just limited to 10 minutes per use. If I could borrow a cord though, that'd save 100 bucks...
Latest musing on my car related shenanigans:
  • Buy consult cable, (this would work, right?)
  • install free Nistune trial software,
  • adjust injector CC and AFM to match,
  • drive car to EFI
  • Profit
Sound like a plan?
That's all I did when I did mine. Just don't go nuts on the way there before the tune.
I'm astonished at the level of risk your taking just to save a few hundred dollars.
Sean will have to recheck EVERYTHING you will have done and in the event something is not right he will have to fix it.
Yes he can easy install AFM and especially injectors, including fuel pump, ECU etc......
Didn't know that, have not been there apart from dyno day (where i was sick as a dog) since ERD closed down.
As far as the ECU goes, i'm talking about changing injector sizes and AFM's. Its a case of putting old and new CC and it scales the map, and selecting Z32 from a drop down list. Not actually messing with any of the ignition/fuel maps etc.
its all at your discretion Pete. All I know is that it's a long way for you to drive the GTR to EFI and if something goes wrong in between..........well it's just a long way
If the nistune scales the map for you, you should not have any problem
Morning Ants... Hows the Ant-Eater going, have you racked up enough "run in" km's yet?
nope........sadly I haven't used since I went to QR with you guys :(
Only done 450km!
I think a long drive is overdue then. Then retune and bring to next happy laps :-)
i agree but bits of car are being reprinted FTM.......plus I'm very busy at work so limited time.
Yes, a full tune with E85 is on the cards ;)
Drive the 32 to work. Problem solved :yes:
 Share
    • to have this type of adjustment possible with a curve as I wish, what budget (engine) should be planned?
    • People still have Skylines? I thought they're non-existent now.
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
    • They do that at random every now and then, with almost no detectable cause. Mine has done it a couple of times (over 25 years!!). Never worked out why.
    • I don't post on here and have been lurking for some time now. Many of the topics have helped me out more times than i can count. I was racing yesterday (11/9) and blew a front right CV shaft. I have spares so I popped a new one in. A thread i read previously said to check the engine mounts if you blow a front CV. Upon inspection, the front right mount was completely separated from the upper plate. This discovery saved me time and money, because i would have blown another CV if i went back out. Just wanted to thank you guys and wish everyone luck with with their builds. (Now if we could only come up with a solution for my power steering belt flying off after hitting the rev limiter, lol)
