Mugabetown - Whoretownin' At It's Worst.
Only thing worse than moving is helping someone else move
Very true, I never expect anyone to help, and on the other hand neither do I expect to be asked to help. It's the worst job ever and no-one needs that sort of painful infliction after a week at work. That's what removalists are for! :D
