Mugabetown - Whoretownin' At It's Worst.
Looking good Scottie
my original thought was to try and keep the stealth look about it.
But then i thought the sound of the car and the big as F*#k drag wing on the rear kind of gives it away lol
Are you coming to happy laps Ants? even if its just spectating and racking up KM's on the Anteater but no tracking
i will see how I go mate. Still got a bit of resto / paint work to do on car before it runs again.
Plus suspension and brakes need some Zac attention :)
Nice one. Mr Scott, how goes the brakes?
Quite good actually .Well the car doesnt get driven all that much but when it went to QR they handled really well. However my mechanic seems to think I put them on upside down. Either way they still seem to work fine
Ants, loving the CF detail in the map pockets. Very nice!
I went through a stage a CF wrapping almost everything. It gets so addictive
How did you manage to put them on the wrong good way around? Pics!
well Richo reckons the bleeder should be on the top and not the bottom like Ive done. SO the Left Caliper should actually be on the right rotor and vise-versa. If you know what I mean...
#@MagicMikeZ32 might be able to shed some light on this?
I reckon he is right
He races cars every weekend so I think he is right as well. HE reckons that there "may" be some air left in them right at the top. So potentionally they will work even better. however the effort of taking them off and on again really doesn't tickle my fancy
I agree. They work really really well once warm now. Hard to think they could be even better!
Also a put a fresh set of plugs in yesterday so my misfiring issue is resolved short term. New coil project in the works though
They won't stop you faster or anything but it will give you a better pedal feel which is always handy.
    • Big R34 GTR parts cleanout. I have a lot of stuff collected over the last 14 years and my missus is giving me hard time. Make my life easy.   Nismo GT carbon fibre diffuser fins (discontinued)  NEW  $2900 Garage Defend Stingray canards carbon fibre  NEW  $1300  Top Secret G Force carbon fibre front diffuser  NEW  $2000  Haltech Elite 2500  NEW  $2500  Haltech Platinum Pro R34 GTR   USED  $1400  Apex’I power FC D'jetro + hand controller R34 GTR   USED  $1400  Nissan OEM BNR34 ECU  USED   $1000  HKS EVC 6  USED  $600  Blitz dual SBC ID boost controller.  USED  $350  TRE 255 LPH Fuel pump  NEW  $100  Fujitsubo  Super Ti exhaust  USED  $2700  Tomei Expreme Ti exhaust  USED  $2000  Trust stainless steel front pipe  USED  $1000  Apex’I super suction kit  USED $400  BC BR coilovers  USED  $600  Hardrace front upper camber kit. USED  $300  Garret 2860-5 turbos –  one good, one needs reco USED  $1000  Nissan OEM Toshiba MFD Screen replacement  NEW  $450  Nissan OEM BNR34 Series II front passenger seat  USED (mint) $5000   Nissan OEM BNR34 front bar in TV2  USED  $1000  Nissan OEM BNR34 front lower air spoiler  USED  $900  Nissan OEM BNR34 front lower air spoiler (painted)  USED  $900  Nismo front indicator (clear) USED  $80 Nissan OEM BNR34 radiator  USED $500  Nissan OEM BNR34 turbos  USED  $500  Nissan OEM BNR34 intercooler USED  $800  Nissan OEM BNR34 front swaybar   USED  $500  Nissan OEM BNR34 intake pipes   USED  $400    Also have a square set of uber rare Volk CE28n in 19*10 +22. Not really keen to sell these but make a high enough offer and maybe I will. If you don't know how much these usually sell for don't bother.   PM for pics.  Pickup Chadstone VIC or postage at buyer's expense.
    • Thanks Mate, I did know you could do that but i know there is a pump out there that you can bolt on and it all lines up. I was told about it and then forgot the model, I figure if i am pulling it apart i will just put a new one on
    • You can also remove the veins from the HICAS portion of your existing pump.
    • Trying to swap the rear subframe on my R34 and can't remove the L-shaped stay brackets between the front subframe mounts and the sill/chassis. I'm in the UK so rust is a problem. I've used loads of WD40 and then Tunap 103 for days beforehand. I backed off the bolts forward a bit, backward a bit repeatedly for ages to try and avoid snapping. They have all moved a few full turns. The one I've spent most time on has come loose and I can turn with fingers, and it will pull down and push up 2-3mm. But it won't come out. I can tighten it back up and loosen it off again repeatedly but it still won't come out. I assumed there's a captive nut inside but if that's broken loose then I can't understand why I can always tighten the bolt back up - I'd expect it to just spin both ways. Any ideas what's happening here? I can't visualise what's inside there to cause this.
    • Cheers, yeah it was recently imported, is the actual Nissan not an Infiniti so will have to do some chasing around for parts.    Any ideas if the side skirts from a Q50 would fit on the 400r?
