Mugabetown - Whoretownin' At It's Worst.
If it was from a standing start, instead of a rolling start where every single factor is in your favor, you should be worried about his powah, but I will say one thing for you, you choose your battles well!
Yes well... I don't like losing. It makes me waste money lol
Scott is Nick's Unicorn. The one he couldn't beat.
This actually happened at Downshift last month.. .Missed 3rd so he had me at half track. Got him back by the end though... Damn kids and there Auto V8's
Thinking like Nick here, and it is scary, but I imagine he is hoping you will miss a gear, then he will never race you again :P
Oh you mean.... Like this:
Bahahaha :rofl:
Questions for Scott,
Are you running E85?
Are you planning to/have done official 1/4 miles with your current set up?
Yes
No
Cars runs E85 only, however i have it flex tuned with sensor....
Yet to run it down the 1/4 mile. Still a few things I want to get changed and adjusted before I go
Yes
No
sweet, thanks! I plan on doing a flex set up at some point too, I am being told that 1000cc injectors wont be enough, I will probably only make 350rwkw max so possibly even the 750cc ones I have now may be enough.
Will be interesting to see what it can do!
I make 420rwkw+ and only run 1000cc injectors
Yeah i noticed that in your sig, people seem to be going nuts on the injectors for e85, yeah you use more but I was suggested 1200s which to me seems very very excessive, and your set up proves that it is.
I think people are moving towards the huge ones as the price difference is pretty much nothing. I think 2000cc ones were like $10 each more expensive for me. I originally went 2000cc injectors but due to 3.oL bottom end the Plazmaman Plenum sits very high in the engine back and the Fuel Rail was fouling on it as the 2000cc's were too tall. So we went smaller. Id say they would be close to their limit though
doubt that very much Bunts.
I make 350rwkw on 98 with 1,000cc.
Although I know that E85 drinks more I'm pretty certain that 400rwkw is safely achieved with 1000cc injectors.
It's the fuel pump that needs to be up to scratch to deliver ;)
In regards to pump, I use intank pump only. Walbro E85 one. Pretty sure this is the one
http://www.sonicperformance.com.au/F90000267/Walbro-Fuel-Pump-Intank-E85-450lph/pd.php
I has exactly the same :)
Yeah the fuel pump I have should be sweet, and I have a surge tank and lift pump ready too, I think I will give it a go on the 750s and cross the running out of flow bridge if I come to it.
Sounds like a good idea. I am not privy to this motor vehicle you are assembling. All i know is it has a Crank trigger setup [Which im learning more about and jealous of lol] and now e85 with a good fuel setup. Sounds like a cool machine in the making
yeah Bunts car should kick some serious bogan V8 ass once she's all done :P
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
