Mugabetown - Whoretownin' At It's Worst.
Scotty we have a car in ATM with this bit broken off
The cas is perfectly fine if you get it in the right tooth
Just get a timing light and chuck it on and make sure it's in the right spot before...... Giving it to it
It should be fine that way even with the broken half but it's completely up to you of you want to replace...... Then I buy cam :devil:
Yeah after a lot a research and asking around Ive found this is actually pretty common
It isn't that expensive, not in the grand scheme of things. And not when you are betting your engine against a 20 year old CAS. Knowing what I know now, a crank trigger and appropriate ecu would have been among the first mods to every skyline I have owned
I definitely agree that its a far better option. If i had the money I would make the change.
Potentially, but more reliability is the real key.
Reliability is always key when making good HP
