Mugabetown - Whoretownin' At It's Worst.
Rb26 oil filter change has defeated me. How the f**k do you get the f**ker out. I think i may need a smaller tool to get to it.
It also feels like the filter on there is smaller than the replacement Z145a one i've got, but that could just be tiredness creeping in
Your Tool is small enough
Morning Ants and Scott.
Rain looks like it's going to hang around for a while. Week feels like it's dragging on. Should hopefully place an auditor today!
Morning Tony,
As much as the rain isnt great. We really do need it.
Correct. A massive downpour is a lot more exciting and short lived
Although the soil isn't really capable of absorbing it all at once and a lot of it runs off so theoretically, shorter bursts of rain is better? Where's bunts? He would be able to answer that. He should stop stalking me on LinkedIn and post here :P
Steady rain over a long time, like we are getting, is the best. Not as much runs off and is stored in sub soil. I was 'stalking' you because I was trying to figure out how to stop stuff that doesn't pertain to me being in my feed. I couldn't.
There's a way. When I'm back at my desk I'll take a look.
    • KYBs are typically twin tube, putting them in the lower tier of desireability. Do you just want to replace worn out ones for the lowest cost? I mean, you wouldn't just replace one end of a car, if the rears are a similar age to the fronts, then they are probably nowhere near what they should be, and likely won't be great against brand new fronts. So, to spend ~$800 on 2nd tier dampers, when you could get a decent set of MCA coilovers for <$4k.....? As to the strut tops. 1st up, the Sparesbox site specifically tells you that they are not correct for an R33. Beyond that, why do you think you need them?
    • That's not very Toyota of the Toyota!
    • Bringing an old thread back to life Looking to put some new front shocks in the r33Gtst and the KYB still look ok for a road car. Unless there are any other options aroind that price $200 a shock?  I’d like to replace the strut tops also, is this the correct KYB no. For the strut top, KSM7124?  https://www.sparesbox.com.au/products/kyb-strut-top-mount-ksm7124?srsltid=AfmBOoq-HDru8wSlLnQrhU9gCw_uYdKg8gUQzONY-EQOdnI5iXOWEUjY 341287 appears to be the front KYB shocks part no.  thanks all
    • LandCruiser used to get a fluid flush every 12 to 18 months.   Only because it was about that often the electric motor on the master for brake assist kept dieing and needing to come off.
